November 20, 2023, 15:38 |
Restart overset simulation from latest time
Hi Foamers,
I am struggling with an overset simulation. I ran a simulation to the time XXX and stopped it there. In a second thought I wanted to restart it from there with a shorter interval of write time. Trying this always gives me the same problem. -> The mesh courant number is much too high and I do not know how to avoid this in the initial start from time XXX. In the second time step the velocity of the overset mesh is much too high which seems to be the result of the initial problem. After this mismatch the simulation does not get better.... I tried to set the time stepping to really very low numbers fot the initial calculation but this seems to be not related in the initial mesh courant number.... Anybody got experience how to fix this? Best regards, Michael |
latest time, latesttime, mesh courant, overset, restart |
Postprocess: sampleDict works but creates no output folder | shock77 | OpenFOAM Post-Processing | 14 | November 15, 2021 08:27 |
Slow calculation time on CFD server | killian153 | Hardware | 4 | July 27, 2021 07:28 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
