No Combustion with reactingFOAM
Old   February 17, 2020, 03:23
Default No Combustion with reactingFOAM
Tobi Wehr
Tobi Wehr is on a distinguished road
Hello, everybody,
i have been working with reactingFoam (the latest OpenFOAM version) for some time now. I've watched the tutorial SandiaD_LTS. For my own simulation and geometry I used this tutorial as a basis.
I also have an inlet for air, an inlet for fuel and also an inlet for pilot. The problem I have is that there is still no combustion. Because of the high temperatures at the interface between the pilot and the fuel-air flow, I expect a temperature increase. But nothing of the same happens to me.
In the beginning you can still see that other species are created by a reaction. But later the number of iterations for this is 0.
Have any of you had this problem before and can you give me a hint or help me?
Thanks a lot!
Greeting
Tobi
Tobi Wehr is offline   Reply With Quote
Old   February 17, 2020, 08:13
Tobi Wehr
No one has any ideas?
Old   July 6, 2020, 18:24
Imed
Imed is on a distinguished road
Send a message via ICQ to Imed Send a message via AIM to Imed Send a message via Yahoo to Imed
Hi there;
did you try the SandiaD_LTS, because it will not working only afer fixing some problems. if you want I can help you.
Imed is offline   Reply With Quote
combustion, radiation, reactingfoam
Using reactingFoam from SandiaD template for H2 O2 non premixed combustion MateusLatt OpenFOAM Running, Solving & CFD 3 April 22, 2018 23:24
How to switch off combustion and reaction in reactingFoam shenzhou1987 OpenFOAM Running, Solving & CFD 16 October 26, 2017 15:31
reactingFoam with Gri-Mech 3.0: No combustion happening a_slow_old_man OpenFOAM Running, Solving & CFD 0 January 6, 2017 05:12
reactingFoam: how do we add more combustion products to reactions in combustion? rewol OpenFOAM Pre-Processing 0 August 10, 2015 14:07
Constant Volume Combustion with reactingFoam Alish1984 OpenFOAM Running, Solving & CFD 2 May 8, 2011 08:51
