Solving coupled steady and unsteady equation in OpenFOAM
Like Tree1Likes
  • 1 Post By jd87
Old   July 18, 2020, 17:26
Post Solving coupled steady and unsteady equation in OpenFOAM
Jayabrata Dhar
jd87 is on a distinguished road
I have two equations, the momentum (velocity and pressure) equation which is steady in my case and a convection-diffusion (transport) equation which is unsteady and drives the flow.
Physically, the momentum spreads much faster and becomes steady before there is any effect from the unsteady transport equation. Thus, I want to couple them. I had few thoughts:
1) To use simpleFoam to solve the steady part and then go for the unsteady inside a time loop. However, simpleFoam itself uses a dummy time loop and there goes the issue.
2) Use pimpleFoam to run the momentum equation until steady and using its results solve the transport equation. So, I have made a custom solver for the 2nd case. But how to tell the pimpleFoam momentum equation (the pimple.loop() function) to only exit pimple.loop() after the momentum equation has reached steady state and then go for the unsteady transport equation?
My overall idea is to make the momentum steady and use it to run unsteady transport and loop over these two (moment and transport) until a convergence is obtained for a particular time point. Then I move on to the next time point and do the same. Is there any better way to do that besides point 2?
neelarun likes this.
jd87 is offline   Reply With Quote
Old   July 21, 2020, 11:22
Klaus
klausb will become famous soon enough
Hmm...
read this page carefully: https://openfoamwiki.net/index.php/O...hm_in_OpenFOAM
You can run pimpleFoam in PIMPLE and PISO mode. PIMPLE uses SIMPLE in each timestep. Practically, do you mean, you want to switch between PIMPLE and PISO mode in each timestep?
Klaus
klausb is offline   Reply With Quote
Old   July 22, 2020, 11:36
Jayabrata Dhar
Thanks for your reply. Yes, I have already looked in the PIMPLE ago. PIMPLE uses a dummy timestep to reach a steady state (that uses SIMPLE), however as it runs that dummy time step to obtain a steady state value, the equation which is actually unsteady also changes its value. So I have two equations one steady momentum (U,p variables) and one transport (say, T as variable) equation. ideally, the term ddt(T) in the unsteady transport equation is broken as (T - T_oldTime)/dt. Now, in changing the dummy time step, the value of T_oldTime will also change while I want it to be constant and want it to only change when the momentum equation (U,p variables) converge along with T for a particular time step. So, the algo goes like:
find converged value for U, p and T equations for a particular incremental dt where U and p have reached their steady state then move on to change the time step dt.
Thanks again.
coupled equations, pimplefoam, steady and unsteady state
iterations process for steady solver and time dependence for unsteady serguei Main CFD Forum 22 May 10, 2018 10:58
Simulating an unsteady phenomenon with a steady model JochemGrietens Main CFD Forum 2 April 13, 2016 11:51
Steady and Unsteady nature Natali_Beginner FLUENT 15 April 21, 2013 12:43
steady or unsteady? (in dpm) winnie FLUENT 1 April 28, 2003 11:30
steady or unsteady equation? Harry Qiu FLUENT 0 April 2, 2001 06:35
