OpenFOAM v5 tutorial interFoam wave
Old   October 8, 2017, 21:31
Default OpenFOAM v5 tutorial interFoam wave
Sungbae Lee
lsb1292 is on a distinguished road
Hello people,
I am new with OpenFOAM and I want to make wave with OpenFOAM.
I found OpenFOAM has wave tutorial so I tried to implement this tutorial
but it did not work.
Anybody can help me to do the wave tutorial?
Anybody can tell me some steps to do this?
Thank you!
lsb1292 is offline   Reply With Quote
Old   April 19, 2018, 00:12
AliG
axjjienn is on a distinguished road
Can you share a little about what happened when you tried to run the interfoam dam break tutorial? It is quite well encapsulated, and should run "out of the box."
axjjienn is offline   Reply With Quote
Old   September 13, 2018, 02:02
Ainal Hoque Gazi
A H Gazi is on a distinguished road
Hi all, i have also tried it and got the following errors
PIMPLE: iteration 1
smoothSolver: Solving for alpha.water, Initial residual = 0, Final residual = 0, No Iterations 1
Phase-1 volume fraction = 0 Min(alpha.water) = 0 Max(alpha.water) = 0
MULES: Correcting alpha.water
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam:utletPhaseMeanVelocityFvPatchVectorField::u pdateCoeffs() at ??:?
#4 Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::GeometricField<Foam::Vector<doub le>, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/interFoam"
#5 ? in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/interFoam"
#6 ? in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/interFoam"
#7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#8 ? in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/interFoam"
Floating point exception (core dumped).
Help please.Thanks
A H Gazi is offline   Reply With Quote
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
[FSI] HronTurek Tutorial OpenFoam extend: no flag movement roma-aeterna OpenFOAM CC Toolkits for Fluid-Structure Interaction 13 October 15, 2019 04:11
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 06:15
Boundary conditions for hassan hemida interFoam tutorial vishal_s OpenFOAM Pre-Processing 0 August 21, 2013 00:21
OpenFOAM WigleyHull tutorial kilroy OpenFOAM Running, Solving & CFD 0 April 1, 2013 21:18
