Flow in a supersonic cavity - RhoCentralFoam
Old   October 6, 2018, 08:36
Default Flow in a supersonic cavity - RhoCentralFoam
madz
maddy11 is on a distinguished road
I'm trying to simulate the flow in a supersonic cavity using Rhocentralfoam solver. But the flow is not started even after 0.00011 s when I view the same in Paraview. My mesh contains 30000 cells in cavity and total 80000 cells. I'm using the Kurganov flux scheme. I'm an Openfoam beginner. Kindly help and let me know if more details are needed!
maddy11 is offline   Reply With Quote
Old   October 6, 2018, 09:13
Peter Baskovich
pete20r2 is on a distinguished road
Originally Posted by maddy11 View Post
If you can, share your case or more information or there isn't much the forum can help with
pete20r2 is offline   Reply With Quote
Old   October 6, 2018, 13:05
clapointe is on a distinguished road
A quick thought before looking at the full case -- many of the rhoCentralFoam tutorials are inviscid. Assuming the cavity flow is lid driven, this is a shear-driven flow meaning that you cannot solve the inviscid problem.
Caelan
clapointe is offline   Reply With Quote
Old   October 8, 2018, 01:44
madz
@Caelan: This is not lid driven cavity. But it is a simulation of an open cavity at Mach 2.0. The shear layer is required to reattach at the cavity rear wall. I have a thesis paper on deep cavity simulation that was done in Rhocentralfoam. That is why I have adapted this solver.
Here is the link: https://fenix.tecnico.ulisboa.pt/dow...638/Thesis.pdf
Kindly tell me if the solver can handle this type of flow.
Maddy
Old   October 8, 2018, 12:15
To be clearer -- make sure that you are solving a viscid problem with rhoCentralFoam when you care about shear/viscous effects. Check to make sure that nu/mu is not set to zero in thermophysicalProperties. Otherwise, as mentioned previously, we will need to see the full case to help diagnose a problem.
Caelan
Old   October 10, 2018, 00:05
madz
Hi Caelan,
Yes, the viscosity value is not zero in my case. I'm able to run the simulation now.
Maddy
Oscillating flow over a cavity validation case Sparow89 FLUENT 0 June 2, 2016 15:18
Inlet problem for turbulent flow in cavity Sebastian A FLUENT 0 January 21, 2016 05:54
Supersonic Inlet for a Compressible Flow in a Nozzle Daco FLUENT 8 November 8, 2012 03:34
Supersonic Flow over a Cavity (coodles): Maximum Iterations Exceeded sushant OpenFOAM Running, Solving & CFD 0 April 9, 2009 02:52
Supersonic flow past cavity Aditya Main CFD Forum 3 November 18, 2005 10:49
