October 9, 2018, 10:23 |
reactingFoam
Rep Power: 10 |
Hey guys,
I have some problems with reactingFoam. I want to simply calculate the combustion on a premixed swirl burner with a methane-air mixture. The problem is that the reaction occurs in the pipe before the swirler. Does anybody have an idea what is the reason for this behaviour? I use a Hybrid-Mesh, PaSR and Phi=1, full-premixed Thank you! Greetings sufjanst |
October 9, 2018, 14:51 |
Rep Power: 14 |
Results for reacting flows are hugely dependent on choice of reaction mechanism and combustion modeling (if at all). If I recall correctly, the PaSR scales the chemical timescale against the turbulence timescale (or vice-versa). If you are seeing unphysical behavior, it could be a good time to reevaluate model coefficients, to look for a mechanism tuned to your application, or to see if there are physics that you are erroneously including or missing (eg preheating). A good first step would be to look at the PaSR model coefficients.
Caelan |
How to switch off combustion and reaction in reactingFoam | shenzhou1987 | OpenFOAM Running, Solving & CFD | 16 | October 26, 2017 15:31 |
strange processor boundary behavior in foam-extend reactingFOAM | Neka | OpenFOAM Bugs | 8 | August 16, 2017 07:13 |
calculate flame speed using reactingFoam | IColin | OpenFOAM Running, Solving & CFD | 0 | February 4, 2014 15:14 |
reactingFoam wedge handling wrong U | dhondupant | OpenFOAM Bugs | 1 | December 9, 2010 07:34 |
reactingFoam - turbulent reacting flow | hamburgFoam | OpenFOAM | 0 | December 7, 2009 12:57 |
