how to limit the velocity and courant number in SonicFoam?
Old   September 13, 2021, 17:37
Default how to limit the velocity and courant number in SonicFoam?
BC
keda xu is on a distinguished road
SonicFoam is applied.
Max Velocity is defined in fvSolution file “UMax”, but the results showed that the velocity limit did not work.
Courant number limit is defined in ControlDict file, but it did not work either. The way how to limit Courant number is from the solutions in this forum。
Anyone knows how to fix these problems?
keda xu is offline   Reply With Quote
Old   September 14, 2021, 01:41
Lukas
Pappelau is on a distinguished road
I never used SonicFoam, but for other Solvers its possible to limit U in the constant/fvOptions file. If you use Foam 9 fvOption is splitted in two parts.
limitU
        type            limitVelocity;
        active          yes;
        selectionMode   all;
        max             40;
Pappelau is offline   Reply With Quote
Old   September 14, 2021, 13:58
BC
Thanks, Lukas, I created fvoptions file in constant and it works. Do you know how to limit courant number?
Old   September 15, 2021, 05:41
Lukas
Courant number can be limited only for transient runs and then it is limited through the controlDict in system
add this :
adjustTimeStep yes;
maxCo           0.25;
#maxAlphaCo      0.05;  #is used for two phaseflows
maxDeltaT       0.1; # upper limit
[OLAFLOW] The OLAFLOW Thread Phicau OpenFOAM Community Contributions 457 March 27, 2024 00:59
Import .csv - velocity profile - error eSKa CFX 9 April 3, 2021 13:38
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
Courant Number waseeqsiddiqui FLUENT 3 December 27, 2018 10:43
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
