October 9, 2018, 01:08 |
UDF for planetary motion
Ansh
Rep Power: 7 |
Hello everyone, iam new to openfoam and for my project i need to describe planetary motion for two blades around one center blade. iam using overPimpleDyMFoam so can anyone point out the right direction to achieve this. Where and how to write UDF?
And how to link it with my present solver? thanks |
October 13, 2018, 06:54 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Ansh and welcome to the forum,
No UDF should be necessary. Since you are likely using OpenfOAM-v1806, please study the respective OpenFOAM Tutorial Guide: https://www.openfoam.com/documentation/tutorial-guide/ - this will give you a better basis on how to get things to work. Then once you are more familiar with how OpenFOAM works, check the tutorial case "tutorials/multiphase/overInterDyMFoam/boatAndPropeller/" and in the file "constant/dynamicMeshDict" you will start to see how the moving parts are defined... Best regards, Bruno
October 15, 2018, 02:36 |
Ansh
Rep Power: 7 |
thanks for quick reply, i have started looking into mentioned tutorials. after adjusting that dynamicmeshdict according to my need iam getting following error
--> FOAM FATAL ERROR: Could not find rho:rho From function void Foam::functionObjects::forces::initialise() in file forces/forces.C at line 204. FOAM exiting i have found other threads related to this bug and i have changed my rhoName to rho as you mentioned there still iam getting this error. Any suggestions function for force in controldict: functions { forces { type forces; functionObjectLibs ("libforces.so"); writeControl timeStep; writeInterval 5; patches (hole1); rho rhoInf; rhoInf 1; CofR (0 0 0); p p; U U; log yes; verbose true; } } |
October 20, 2018, 15:35 |
Bruno Santos
Rep Power: 128 |
Quick answer: Details, details, details... I need details... Please check the following thread for more information on how to provide mode details: How to give enough info to get help
Because my best guess right now is that you've used the wrong command to start the simulation... What I mean is that the "rho" field should exist when the solver starts running... so if it doesn't exist, then it might mean that you've tried using it with the wrong application. |
October 22, 2018, 01:17 |
overPimpleDymFoam rigid body motion rho not found
#5 | |
Ansh
Rep Power: 7 |
iam intending to use rigid body motion in overPimpleDyMFoam since i want to give planetary motion to the blades (fig is attached) mesh.jpg
where outer two blades will rotate and revolve arround the centre blade. I have followed the overInterDyMFoam from multiphase flow to achieve that motion iam attaching my conrolDict,forceCoeffs and dynamicMeshDict for reference dynamicMeshDict Code:
motionSolverLibs ("librigidBodyMeshMotion.so"); dynamicFvMesh dynamicOversetFvMesh; //dynamicOversetFvMeshCoeffs //{ // layerRelax 0.3; //} motionSolver rigidBodyMotion; solver { type Newmark; gamma 0.1; // Velocity integration coefficient beta 0.1; // Position integration coefficient } accelerationRelaxation 1.0; //- prescribedRotation requires some sub-iterations to converge faster // to desired value. nIter 3; bodies { movingzone2 { type rigidBody; parent root; // Cuboid mass -- very simple setup. For more complicated shapes // see utility surfaceInertia mass 9; rho 1; inertia (0.05 0 0 0.05 0 0.05); centreOfMass (0.21 -0.07 0); // relative to the centreOfMass // of parent body // (here root = global coord system) // Transformation tensor and centre of rotation transform (1 0 0 0 1 0 0 0 1) (0.21 0 0); joint { type composite; joints ( { type Pxyz; // Allow movement in any direction } { type Rxyz; // Allow rotation along any axis // (local - body CS) } ); } patches (hole2); innerDistance 100; // With overset we want to avoid the mesh // deformation so have large innerDistance outerDistance 200; } // end hull movingzone1 { type rigidBody; parent movingzone2; centreOfMass (-0.228 0.0 0); mass 1; rho 1; inertia (0.001 0 0 0.001 0 0.001); transform (1 0 0 0 1 0 0 0 1) (-0.228 0 0); patches (hole1); innerDistance 100; outerDistance 200; joint { type Rx; } } //end propeller movingzone3 { type rigidBody; parent movingzone2;//root; centreOfMass (-0.265 0 0); mass 1; rho 1; inertia (0.001 0 0 0.001 0 0.001); transform (1 0 0 0 1 0 0 0 1) (-0.265 0 0); patches (hole3); innerDistance 100; outerDistance 200; joint { type Ry; } } solid-background { type rigidBody; parent movingzone2;//root; centreOfMass (-0.265 0 0); mass 1; rho 1; inertia (0.001 0 0 0.001 0 0.001); transform (1 0 0 0 1 0 0 0 1) (-0.265 0 0); patches (hole3); innerDistance 100; outerDistance 200; joint { type Ry; } } } restraints { movingzone1Rotation { type prescribedRotation; body movingzone1; referenceOrientation (1 0 0 0 1 0 0 0 1); axis (0 1 0); // Axis of rotation omega sine; // Function1 entry omegaCoeffs { frequency 4; amplitude 0.2; scale (0 1 0); level (0 1 0); } } movingzone3Rotation { type prescribedRotation; body movingzone3; referenceOrientation (1 0 0 0 1 0 0 0 1); axis (1 0 0); omega table ( (0 (0 0 0)) (1 (16 0 0)) ); } } } controlDict Code:
FoamFile { version 2.0; format ascii; class dictionary; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // libs ("liboverset.so" "librigidBodyDynamics.so"); application overPimpleDyMFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 5; deltaT 0.0000000025; writeControl adjustableRunTime; writeInterval 0.005; purgeWrite 0; writeFormat binary; writePrecision 10; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; adjustTimeStep yes; //maxCo 1; maxCo 5.0; maxAlphaCo 5.0; maxDeltaT 1; functions { #include "forceCoeffs" } forceCoeffs Code:
forceCoeffs { functionObjectLibs ("libforces.so"); writeControl timeStep; timeInterval 1; patches (walls); rho rhoInf; // Indicates incompressible rhoInf 1; p p; U U; // Redundant for incompressible liftDir (0 0 1); dragDir (1 0 0); CofR (0 0 0); // Axle midpoint on ground pitchAxis (0 1 0); magUInf 20; lRef 1.42; // Wheelbase length Aref 0.75; // Estimated /* binData { nBin 20; // output data into 20 bins direction (1 0 0); // bin direction cumulative yes; } */ } and error that iam getting Code:
Creating interpolatedCells field Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Selecting laminar stress model Stokes Reading/calculating face velocity Uf No MRF models present No finite volume options present Courant Number mean: 0 max: 0 Starting time loop Courant Number mean: 0 max: 0 deltaT = 2.9999994e-09 Time = 3e-09 forces forces: Not including porosity effects --> FOAM FATAL ERROR: Could not find rho:rho From function void Foam::functionObjects::forces::initialise() in file forces/forces.C at line 204. FOAM exiting Quote:
1)does that mean i cannot use rigid body motion with overPimpleDyMFoam(since while using it only i have started facing this error ) 2)can anyone recommend any literature available related to this? pardon my immaturity with openfoam |
October 27, 2018, 13:14 |
Bruno Santos
Rep Power: 128 |
Quick answers:
1. I've tested with OpenFOAM-v1806 as a Docker image. I used the tutorial case "incompressible/overPimpleDyMFoam/twoSimpleRotors" as a basis and did the modifications that you mentioned to the controlDict file, namely:
It also worked when I ran the solver with the "-postProcess" option, after I had a few time steps already written to disk: Code:
overPimpleDyMFoam -postProcess Mmmmm... this sounds like either a bug or some detail is missing for that type of rigid body motion... You may want to report this at http://develop.openfoam.com/ - although you may need to provide a simple test case, so that it's easier to reproduce the problem and fix it. 2. The documentation provided here: https://www.openfoam.com/documentation/ - should already have a considerable amount of information... check the "Extended Code Guide" page for more details, although it may be a bit confusing at first to navigate there. |
openfoam, planetary mixer, udf |
UDF CG motion | Sam1990 | Fluent UDF and Scheme Programming | 1 | May 9, 2017 16:22 |
Display Zone motion of a dynamic mesh????Checking my UDF motion | Irenedea | FLUENT | 0 | March 20, 2014 02:17 |
UDF to control motion NOT about CG | LenDawg0220 | Fluent UDF and Scheme Programming | 0 | July 28, 2012 12:54 |
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! | alban | Fluent UDF and Scheme Programming | 2 | June 8, 2010 18:54 |
UDF error CG Motion | Alex | FLUENT | 0 | March 22, 2006 17:40 |
