positive bounding k
Old   October 25, 2018, 04:29
Default positive bounding k
CFD_Lovers
sinatahmooresi is on a distinguished road
Hi FOAMers!
I'm facing with something weird during case running using k-epsilon
The problem:
When i pause the running in every arbitrary time (with saving of course) and i start to run the case from last saved time step, i get bounding error for k . This is not happen when the case is running non stopping. Only after make the case stop and start again! So how could it be explained?
Regards
sinatahmooresi is offline   Reply With Quote
Old   October 27, 2018, 21:04
Anonymous
backscatter is on a distinguished road
Originally Posted by sinatahmooresi View Post
Hi FOAMers!
The problem:
Regards
Check your mesh. Usually non-orthogonality or the cells with very small determinant (too planar cells (drastic aspect ratio)) gives rise to these issues.
Try running:
checkMesh -allGeometry -allTopology
and see if your mesh is good enough.
If there is nothing wrong with the mesh, then you need to use bounded/limited div and grad schemes.
Thanks,
backscatter is offline   Reply With Quote
Old   October 28, 2018, 02:48
CFD_Lovers
Try running:
Thanks,
Hi!
Thank you very much, I Got the idea. your hints waas helpful.
[isoAdvector] Is it possible to add isoAdvector capabilities to interphaseChangeFoam? chaohui OpenFOAM Community Contributions 8 August 17, 2020 03:16
Problem about Rotor simulation whit high rotating speed Thomas pan OpenFOAM Running, Solving & CFD 4 June 20, 2018 06:24
Bounding Issues in reactingMultiphaseEulerFoam doubledang OpenFOAM Running, Solving & CFD 1 February 7, 2017 18:43
Bounding k and epsilon & coldEngineFoam sasanghomi OpenFOAM 1 September 13, 2013 12:12
MRFSimpleFOAM goes divergenced! renyun0511 OpenFOAM Running, Solving & CFD 0 November 19, 2009 02:11
