chtMultiRegion not solving for velocity field |
October 30, 2018, 03:43 |
Obi
Rep Power: 9 |
I've been trying to do a simulation in chtMultiRegionFoam and i'm experiencing some problem which i cant understand why its happening. The simulation runs but for some weird reasons, it solves for all other field asides from the velocity. What is the reason for this? It's totally strange as i don't get any error messages . Below is a code excerpt from the run Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 6-1a0c91b3baa8 Exec : chtMultiRegionFoam Date : Oct 30 2018 Time : 03:36:28 Host : "Obi" PID : 6268 I/O : uncollated Case : /home/obi/OpenFOAM/obi-6/run/heatedShell/case nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create fluid mesh for region air for time = 0 Create solid mesh for region copper for time = 0 *** Reading fluid mesh thermophysical properties for region air Adding to thermoFluid Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Adding to rhoFluid Adding to UFluid Adding to phiFluid Adding to gFluid Adding to hRefFluid Adding to ghFluid Adding to ghfFluid Adding to turbulenceFluid Selecting turbulence model type laminar Selecting laminar stress model Stokes Adding to reactionFluid Combustion model not active: combustionProperties not found Selecting combustion model none Adding to radiationFluid Selecting radiationModel none Adding to KFluid Adding to dpdtFluid Adding to fieldsFluid Adding to QdotFluid Adding MRF No MRF models present Adding fvOptions *** Reading solid mesh thermophysical properties for region copper Adding to thermos Selecting thermodynamics package { type heSolidThermo; mixture pureMixture; transport constIso; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } Adding to radiations Selecting radiationModel none Adding fvOptions PIMPLE: Region air PIMPLE: No convergence criteria found PIMPLE: Region copper PIMPLE: No convergence criteria found PIMPLE: Operating solver in PISO mode Region: air Courant Number mean: 0.1039141 max: 0.6005547 Region: copper Diffusion Number mean: 0.06942615 max: 52.37995 deltaT = 0.0001666667 Region: air Courant Number mean: 0.01731902 max: 0.1000924 Region: copper Diffusion Number mean: 0.01157103 max: 8.729991 deltaT = 0.0001666667 Time = 0.000166667 Solving for fluid region air diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCGStab: Solving for h, Initial residual = 1, Final residual = 5.120642e-09, No Iterations 2 Min/max T:295.943 400 GAMG: Solving for p_rgh, Initial residual = 0.9999859, Final residual = 0.004941267, No Iterations 3 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0.01802565, global = 0.0002057503, cumulative = 0.0002057503 Min/max rho:-11.58785 9.216414 GAMG: Solving for p_rgh, Initial residual = 0.05691773, Final residual = 7.67363e-08, No Iterations 16 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 5.597979e-07, global = -1.020733e-08, cumulative = 0.0002057401 Min/max rho:0.8689607 1.506732 Solving for solid region copper DICPCG: Solving for h, Initial residual = 1, Final residual = 9.8895e-07, No Iterations 2 Min/max T:290.7127 332.6187 ExecutionTime = 4.52 s ClockTime = 19 s Region: air Courant Number mean: 2.546197 max: 8923.591 Region: copper Diffusion Number mean: 0.01157103 max: 8.729991 deltaT = 1.867707e-08 Time = 0.000166685 Solving for fluid region air diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCGStab: Solving for h, Initial residual = 0.0007881029, Final residual = 6.475526e-09, No Iterations 1 Min/max T:290.7155 400 GAMG: Solving for p_rgh, Initial residual = 0.01570502, Final residual = 2.354311e-13, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.28292e-10, global = -2.830048e-12, cumulative = -2.830048e-12 Min/max rho:0.8695844 1.547143 GAMG: Solving for p_rgh, Initial residual = 0.001365404, Final residual = 3.268448e-14, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 9.170082e-12, global = -5.047294e-15, cumulative = -2.835095e-12 Min/max rho:0.8695845 1.50835 Solving for solid region copper DICPCG: Solving for h, Initial residual = 5.203124e-05, Final residual = 7.670816e-16, No Iterations 1 Min/max T:290.7117 332.6234 ExecutionTime = 5.06 s ClockTime = 20 s Region: air Courant Number mean: 0.0002648757 max: 0.4671027 Region: copper Diffusion Number mean: 1.296677e-06 max: 0.0009783038 deltaT = 2.241238e-08 Time = 0.000166708 |
October 30, 2018, 04:08 |
#2 | |
Ricky
Rep Power: 11 |
Hallo,
The only thing I can think of right now is switching on the momentumPredictor in system/air/fvSolution Code:
PIMPLE { momentumPredictor on; nCorrectors 2; nNonOrthogonalCorrectors 0; } Regards, Ricky Quote:
If it is easy, then something is fishy! |
October 30, 2018, 04:47 |
#3 | |
Obi
Rep Power: 9 |
The momentum predictor on my fvSolution file was already on. Seems that's not the problem here. Please have a look at my case file and see if you could spot something wrong. https://www.dropbox.com/s/xs660es6v7...hell2.zip?dl=0 Thanks very much. Last edited by obiscolly50; October 30, 2018 at 10:24. Reason: updated link |
October 30, 2018, 05:16 |
Peter Hess
Rep Power: 17 |
The log file for subsetMesh have an error! (I tested with OF6.0). The splitMeshRegions split the mesh into 77 regions... You need to fix the problem in the meshing first. I am woundering how the simulation runs by you. OF version? You are simulating transient. Is that right? Setting maxCo 10000; is not a good idea. Better to reduce to 1, supposing you simulate transient... Regards Peter |
October 30, 2018, 10:30 |
#5 | |
Obi
Rep Power: 9 |
Thanks for checking up on my case. Sorry it was my bad! I have fixed the case to have only 2 regions now. 77 regions were created because subsetMesh failed due to not removing some old cellToRegion files using my AllClean script. Also, i'm actually using a maxCo of 1. I've been trying different settings to see the cause of the problems, that's why it was at 1000, but i've changed it back. Please have a look at let me know your thoughts. Here is the new link: https://www.dropbox.com/s/xs660es6v7...hell2.zip?dl=0 Thank you very much. |
October 30, 2018, 10:41 |
Peter Baskovich
Rep Power: 11 |
I can't open the zip on my phone so I'll just guess, you don't have frozenFlow on do you?
If that's not it, go have a look at the source for chtMultiRegionFoam and find any "if" statements or other conditionals that might cause a skip of the U solution. |
October 30, 2018, 10:54 |
#7 | |
Obi
Rep Power: 9 |
Thank you! |
November 1, 2018, 02:57 |
Peter Hess
Rep Power: 17 |
Hello!
I rebulit the mesh you have in your case using salome and used the setups you have in your case. Your mesh has different problems, as checkMesh has told me. All The boundary condithins, themophysical proberties... has been imported from your case. I just changed the mesh and the velocity at the outlet from zeroGradient to inletOutlet. The simulation works. That means that your setups are working. The problems you are facing is by using the: - snappyHexMesh -overwrite If you look to the log file of snappy, you will notice that the maximum number of cells need to be increased in snappy from 200000 to a higher value! That need to be done, but does not solve the problem! - setSet -batch batch.setSet and - subsetMesh -overwrite isolation I have no idea what you want to do with those two. Anyway you are isolating the sourrounding boundaries and take them out of the simulation. And that includes the inlet and the outlet. Would you please descibe the target of using those two utalities. ie what you want to do? Anyway, here is the case meshed with salome. https://drive.google.com/file/d/1OhW...ew?usp=sharing Do you want to simulate transient or steady state? Regards Peter PS: The gravity should be in Z direction! Last edited by peterhess; November 1, 2018 at 07:34. Reason: updated link |
November 1, 2018, 07:48 |
#9 | |||||
Obi
Rep Power: 9 |
Thanks a lot Peter for the time you spent looking into my case. I've learnt several things from your last reply that should hopefully help me in future cases. Regarding your question below:
From my understanding (maybe i'm wrong), the background mesh is not totally removed after using blockMesh. I experienced this and that was the reason it created 77 regions as you pointed out previously. So, it would seem from the post, setSet was used to create a cellZone isolation which includes the needed zone (air and copper) and the subSetMesh command is used to tell OpenFOAM to create a new mesh from the 'isolation' and overwrite existing mesh. This has been my philosophy for the past couple of weeks i started learning chtMultiRegion. Quote:
Once again, thanks for your great work Peter! |
November 1, 2018, 08:05 |
#10 |
Peter Hess
Rep Power: 17 |
I'm trying to simulate transient, but the simulation timestep is painfully slow using a maxCo of 1. I wonder how that could be increased without using much larger cells. Anyway, it is my understanding that chtMultiRegion doubles as as both a steady state and transient solver. To change to steady, i just need to switch the ddtScheme to 'steadyState' and change PIMPLE to SIMPLE in fvSolution? Please correct me if i'm wrong.
Yes you are right! ddt --> steady state and using the fvSchemes and fvSolution from: /heatTransfer/chtMultiRegionFoam/multiRegionHeaterRadiation/ for solid and fluid regions respectvly Those setups are working... --------- The transient simulatiuon is running very slow. You are right! The reason for this is the very high density of the solid region (copper) in your case! rho =8000 means that the solid will take too much time to increase its temperature because the momentum is very high. By the way, if the transient part of the simulation is not necessery, then the "transient" simulation calculation time could be increased by reducing the density of the solid to 1! AND increase the maxCo. Anyway a devergence could happend... After the convergence happends you can increase the density one more time to get the final results. Like that you dont need to change the ddt sheme and fvSchemes and fvSolution! This suggestion is not official, but a small trick if you want to use the transient setups for a steady state calculation... ------------- OK, if the gravity is right, then I was worng ------------- The problem with your mesh is that you have a very coarse stl mesh. (I am not sure here). Snappy setups need to be tuned to get a good mesh. After snappy and before making the next steps, just run checkMesh. You will notice that the mesh quality is bad and checkMesh failed. I increased the blockMesh resolution and the 2000000 cells in snappy to 20000000. but I was not succesful... That why I made the mesh with salome, caus I like it more. At the ende of snappy you get a massage: Finished meshing with 76 illegal faces (concave, zero area or negative cell pyramid volume)! ------------- The geometry is by the way very simple and you are able to make the mesh with blockMesh and topoSet, without using snappy ------------- I am working now on the case using snappy. I will post it later |
November 1, 2018, 08:56 |
#11 | ||||
Obi
Rep Power: 9 |
November 1, 2018, 12:56 |
#12 |
Peter Hess
Rep Power: 17 |
I got it
The problem was in the stl files you use. I just replaced yours with others that I generated myself. Deleted the: setSet -batch batch.setSet subsetMesh -overwrite isolation I did not change anything else. See attached file. And have fun https://drive.google.com/file/d/1POc...ew?usp=sharing regards Peter |
November 1, 2018, 13:55 |
#13 | |
Obi
Rep Power: 9 |
I never knew that would be an issue as far as both surfaces are closed. I particularly checked using surfaceCheck to be sure. Please tell me how you generated the stl that might be different from what i did previously? Thank you very much, Obi |
November 1, 2018, 14:04 |
#14 |
Peter Hess
Rep Power: 17 |
Well, I used Salome before to generate the mesh.
From the geometry that I generated there based on your geometry I generated the STL files. By the way, the quality of my STLs is lower than yours! I increased the quality and got the same problem... If you compare the size of my files with yours, then you will see that my files are smaller. ---------- You could increase the maxDi from 10 to about 20. That will let the simulation run faster. Regards Peter PS: Use salome! it is amazing |
November 1, 2018, 14:14 |
#15 | |
Obi
Rep Power: 9 |
I thought a higher size STL means better quality? It's confusing how a lower quality should work and a higher one fails. Is there any possible reasoning behind that? Also are you generating the STL's from the mesh or geometry module? I need to be clear. If from the mesh module, what rule of thumb do you use for the meshing? same size? |
November 1, 2018, 14:49 |
#16 |
Peter Hess
Rep Power: 17 |
I have no idea.
I descovered that by sudden, as I exported the STL from salome with very high quality. The result was that I got more stand alone zones using spliteMesh. Anyway, I increased before the mesh quality in snappy in the lines: 138 and 148. And the stand alone zones increased. I reduced the quality and I got less stand alone zones. That was the key to look for STL quality and to generate them myself. I decreased the quality to have fun seeing the result and that solved the problem Anyway, I learned today something new The STLs has been generated from the geometry. Regards Peter |
November 1, 2018, 15:03 |
#17 | |
Obi
Rep Power: 9 |
Please tell me. How do you adjust the quality of the stl from geometry module during export? |
November 1, 2018, 15:40 |
#18 |
Peter Hess
Rep Power: 17 |
Yes the mesh exports STL. You are right...
November 1, 2018, 16:02 |
#19 |
Obi
Rep Power: 9 |
November 3, 2018, 16:44 |
#20 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all,
I'm following up a bit on this thread, after a couple of PMs that Obi sent me. I'm quoting most of the latest PM here, so that the answer can be public and contextualized (@Obi I hope you don't mind): Quote:
So my guess is that when the STLs were made coarser, all of the vertices were perfectly coincident without any doubts on how both sides of the inner box (in my hypothesis) would match. So, what if the hypothetical boxes are side by side? Technically, you should ensure that the same exact solid block for the shared surface is used in both within each STL files, so that the solid entry has the exact vertex definitions, without any mildly different digits. Not exactly a practical solution, if you exported the STL files from elsewhere, I know... but from my experience, that's how you ensure snappyHexMesh behaves properly for multi-region meshes. As for the extra regions: I haven't looked into the STL files myself, so my guess is that there is an ambiguous surface overlap where the additional regions appeared. For example, if two contiguous boxes were meant to have a matching vertex that is shared by both, but ended up not matching and having the two vertexes end up inside the other box. I hope this at least somewhat helps... if it's necessary, I can try and look into the case and STL files myself, to try and give a better diagnosis on what happened. Best regards, Bruno
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 17:36 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
