It returns blockMesh
Old   August 3, 2019, 10:44
Question It returns blockMesh
Semih
engingreed is on a distinguished road
Hello everyone,
I've faced an interesting problem. I use surfaceFeatures, blockMesh, snappyHexMesh respectively. After that when I turned mesh to vtk and examine that with paraFoam. I see my meshed zones. Everything was OK. But after I run the simulation with my solver type (simpleFoam etc.). It solved the problem. After, when I opened paraview for post-processing. In time 1 and 2 I saw my blockMesh and snappyMesh. But in time 3 I saw again block to the end of simulation type.
Also it gives that eror:
FOAM Warning :
From function static Foam::vectorField Foam::snappySnapDriver::calcNearestSurface(const Foam::meshRefinement&, const scalarField&, const indirectPrimitivePatch&, Foam:ointField&, Foam::vectorField&)
in file snappyHexMeshDriver/snappySnapDriver.C at line 1638
For point:648561 coordinate21835.9 787.5 -3974.72) did not find any surface within:109.375 metre.
engingreed is offline   Reply With Quote
simplefoam gamg, snappy hex mesh
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 19:15
[snappyHexMesh] Cylindrical blockmesh to Improve snappyHexMesh Results nicholas.jones OpenFOAM Meshing & Mesh Conversion 3 May 16, 2019 09:52
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 08:37
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 11:59
