Error setting fvSolution PIMPLE
Old   December 4, 2018, 04:10
Default Error setting fvSolution PIMPLE
Max
xneop is on a distinguished road
i am new in OpenFOAM and i set up fvSolution file for PIMPLE, but i am getting an error message :
Build : 4.0-244e6aa02817
Exec : interFoam
Date : Dec 04 2018
Time : 08:33:34
Host : foam
PID : 3632
CtrlDict : "/home/foam/Desktop/Simulations/Model3/Model3Sim/system/controlDict"
Case : /home/foam/Desktop/Simulations/Model3/Model3Sim
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0.0001
PIMPLE: max iterations = 50
field pd : relTol 0, tolerance 0.0001
field U : relTol 0, tolerance 0.0001
Reading g
Reading field pd
Reading field alpha1
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Calculating field g.h
--> FOAM FATAL IO ERROR:
keyword PISO is undefined in dictionary "/home/foam/Desktop/Simulations/Model3/Model3Sim/system/fvSolution"
file: /home/foam/Desktop/Simulations/Model3/Model3Sim/system/fvSolution at line 21.
From function dictionary::subDict(const word& keyword) const
in file db/dictionary/dictionary.C at line 456.
FOAM exiting
this is fvSolution file:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
"alpha1.*"
nAlphaCorr 1;
nAlphaSubCycles 4;
cAlpha 2;
MULESCorr yes;
nLimiterIter 2;
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-07;
relTol 0;
pcorr
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0;
pd
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0.1;
pdFinal
solver PCG;
preconditioner DIC;
tolerance 1e-07;
relTol 0;
U
solver BiCGStab;
preconditioner DILU;
tolerance 1e-06;
relTol 0;
/*PISO
cAlpha 2; // alpha correctures
PIMPLE
nOuterCorrectors 50;
nCorrectors 2;
nNonOrthogonalCorrectors 2; // skewness
//nAlphaCorr 1;
//nAlphaSubCycles 4;
pRefCell 0;
pRefValue 0;
residualControl
pd
tolerance 1e-4;
relTol 0;
U
tolerance 1e-4;
relTol 0;
relaxationFactors
fields
pd 0,4;
pdFinal 0,4;
equations
U 0,6;
".*" 1;
i don't understand why he is still asking for PISO
could anyone has an idea pls?
xneop is offline   Reply With Quote
Old   December 4, 2018, 05:58
Allen George
allenjohngeorge is on a distinguished road
Did you notice the symbols /* and */ on the fvSolution code:
/*PISO
this means that this part of the code wont be executed while running. Remove those symbols and try again.
allenjohngeorge is offline   Reply With Quote
Old   December 4, 2018, 06:33
Max
Hi Allen,
yes i noticed, i commented it out, because i want to run PIMPLE. Actually with nOuterCorrectors > 1, i am not suppose to have this error
Old   December 4, 2018, 07:31
Daniel
Daniel_Khazaei will become famous soon enough
Originally Posted by xneop View Post
Hi Allen,
if you are running the extend version, that's because interfaceProperties library reads cAlpha value from PISO sub-dict! you need to un-comment it! It doesn't mean that the solver is going to run using PISO algorithm...
Daniel_Khazaei is offline   Reply With Quote
Old   December 4, 2018, 08:31
Max
Hi Daniel,
ok i will retry again
thx
Old   December 4, 2018, 11:12
Max
Hi Daniel,
i have tried, but for large time step it crashes, i had to choose 1e-6 . i am simulating multiphase flow interFOAM VOF. i have read that with PIMPLE Large time step is not a big deal
Old   December 4, 2018, 11:16
Allen George
Hi Daniel,
What is your courant number in the iterations before crashing ?
Although it says that PIMPLE can handle courant numbers above 1, from my experience, when the courant number goes above 1, the solution crashes after few time steps. I would suggest to keep the courant number close to 0.5 for stable solutions.
Old   December 4, 2018, 11:37
Daniel
Hi Daniel,
well with interFoam and multiphase simulations, I don't suggest using large time step although you are using PIMPLE! For better stability don't go beyond Co 1 and for better accuracy for complex multiphase problems limit the Co to 0.2 using auto-time stepping!
you may want to turn MULESCorr on, it will allow for larger time steps with semi-implicit volume fraction formulation!
Old   December 4, 2018, 14:27
Max
my courant is 5, but i will change it to 1 and see what happens. thx
Old   December 4, 2018, 14:29
Max
Hi
i have tried using the suggested adjustement, but it only works without crashing with time step starting from 1e-6 and i have to simulate up to 60s with a velocity of 4e-6 m/s
PIMPLE – the value of the final under-relaxation factor Zbynek OpenFOAM 9 December 22, 2023 05:26
How to use PIMPLE properly? floquation OpenFOAM Running, Solving & CFD 25 December 2, 2021 09:40
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
error while running modified pimple solver R_21 OpenFOAM Programming & Development 0 May 28, 2015 06:59
A question on the PIMPLE algorithm GerhardHolzinger OpenFOAM Running, Solving & CFD 4 February 13, 2015 06:49
