Difference between IDefault and G (radiation)
Like Tree14Likes
  • 1 Post By FlyingCat
  • 5 Post By TobM
  • 1 Post By HannesJo
  • 5 Post By FlyingCat
Old   October 4, 2016, 11:22
Default Difference between IDefault and G (radiation)
Jean bon
FlyingCat is on a distinguished road
Sorry but I am a new OpenFOAM user so maybe it is an easy question.
When the radiation is activated, we must have two files of boundary condition: G and IDefault. I understand that G gives the Marshak boundary condition to the walls (usually). Then, IDefault gives greydiffusivewalls (in tutorials). I do not understand that. It appears to be redundant to me, we already give a radiation boundary condition.
So I just would like to know the meaning of this two files. I think there is something that I do not understand.
Thanks.
SharpS likes this.
FlyingCat is offline   Reply With Quote
Old   October 10, 2016, 03:56
Jean bon
Nobody knows ?
Old   October 10, 2016, 07:55
TobM is on a distinguished road
G is used for P1 model, IDefault for fvDOM model and Qr for viewFactor model.
KTG, john myce, parthigcar and 2 others like this.
TobM is offline   Reply With Quote
Old   October 10, 2016, 08:07
Jean bon
Thank you for the response.
Old   February 17, 2017, 12:30
nasir musa yakubu
esujby is on a distinguished road
Hi, from my understanding, G is incident radiation and iDefault is radiation intensity ray which calculates radiation intensity.
G= Qin + Qem
so if you think about it this way, G is the total heat that's been absorbed and emitted within a media and IDefault which i believe is used for calculating Qin, which stands for incident radiation heat flux. not too sure but you can easily find out using the search box here, its pretty effective.
http://www.openfoam.com/documentatio...b34c63f9ffab05
That's IDefault
https://github.com/OpenFOAM/OpenFOAM...IntensityRay.C
esujby is offline   Reply With Quote
Old   March 7, 2017, 11:40
Jean bon
Actually, Qr=Qin-Qem where Qem is emissivity*Sigma*T⁴
I have checked it with an easy case. Qin is the total incident radiative heat flux field.
G is used with the P1 model. But, even if I use the fvDOM method, OpenFoam calculates G. G is incident radiation.
Actually, we have Qr=-1/(3a)*grad(G) (if we do not have scattering).
So I do not understand one thing. Why do we call G the incident radiation ? Qin and G are different but their name seem to be the same for me. Both are in W/mē and it is what the wall receives. If someone can explain what is the physical difference between G and Qin, I would be grateful.
Old   March 7, 2017, 13:32
nasir musa yakubu
Hello Fabien,
hmm interesting: well looking at the source code, it shows that Qr, Qin and Qem are independently calculated:
void Foam::radiation::fvDOM::updateG()
G_ = dimensionedScalar("zero",dimMass/pow3(dimTime), 0.0);
Qr_ = dimensionedScalar("zero",dimMass/pow3(dimTime), 0.0);
Qem_ = dimensionedScalar("zero", dimMass/pow3(dimTime), 0.0);
Qin_ = dimensionedScalar("zero", dimMass/pow3(dimTime), 0.0);
forAll(IRay_, rayI)
IRay_[rayI].addIntensity();
G_ += IRay_[rayI].I()*IRay_[rayI].omega();
Qr_.boundaryFieldRef() += IRay_[rayI].Qr().boundaryField();
Qem_.boundaryFieldRef() += IRay_[rayI].Qem().boundaryField();
Qin_.boundaryFieldRef() += IRay_[rayI].Qin().boundaryField();
in my case, for example, Qr=Qin, however......
to answer your question specifically
G accounts for the black body radiation and is the summation of all radiation contribution from all rays and can be calculated my multiplying the intensity of the ray by its solid angle.
so once G is updated, Qr, is calculated from G. and I as you clearly stated in your last reply, the Qem and Qin are then calculated.
However, i would reconfirm this with an expert like Bruno santos if i were you
Old   March 13, 2017, 05:12
Jean bon
Well I think you are right concerning the calculations of each parameter.
But my last question is what is the difference between Qin and G ? They have similar names but it is not the same thing. What is the power received by the wall for example, Qin or G ?
Thank you for your responses.
Old   March 13, 2017, 14:18
nasir musa yakubu
they are completely different!!!!
if you try to run a simple case, you will realize that Qin is only calculated at the boundary and G is calculated on the boundaries and throughout the region itself.
Qin is the energy generated at the surface. for example, if you have a black body under the sun, Qin will be the heat flux on the intercepting surface, which will be conducted by the regions bellow the surface.
in practical terms, Qin is calculated based on absorptivity value.
G, like I said earlier, is:
G is the radiation contribution of all rays, sort of like the average distribution of heats flux throughout the region.
I will confirm all these details with an expert like Bruno Santos and a few others.
Old   April 9, 2017, 21:09
nasir musa yakubu
i am wondering where you got this from? is it based on your results?
Old   April 10, 2017, 03:07
Jean bon
here:
https://www.sharcnet.ca/Software/Flu...ug/node577.htm
It is the user guide of fluent. We use the same boundary condition (Marshak) in OpenFOAM so I guess G is the same for both softwares.
Old   November 24, 2017, 09:30
HannesJo is on a distinguished road
In my opinion the calculation of G in the fvDOM model is wrong. At our institute we developed our own and improved view factor model and work with it quite a lot. We also calculate and write the G-field there and so I compared both models in a test case. I found out that the G-field differs exactly by a factor of 4. I digged in the source code and found the calculation of G:
However, according to theory (for example "Incropera: Introduction to Heat transfer") G equals Pi*I over the whole hemisphere. With the above sum one obtains G equal Pi*4*I, so that G is wrong by a factor of 4. As G is not used to calculate wall temperatures but just the absorbtion inside the fluid, probably nobody noticed so far.
Do you agree with me and should I write a bug report? I never did this so far
chenludut likes this.
HannesJo is offline   Reply With Quote
Old   November 24, 2017, 10:02
Jean bon
It is not wrong neither in OpenFOAM nor in your book. The difference simply comes from the definition of G.
I had a look into your book and the parameter G is calculated only on one hemisphere so
\int d\Omega=\pi
But on the whole space, the solid angle is worth 4\pi.
The factor 4 comes from this.
Old   November 24, 2017, 10:39
thanks for your quick reply. So far, I just have seen G with the definition in the book, I have never seen G defined by I*4*Pi.
When I look at the source term for the fluid, you seem to be right as the emission term is 4 \sigma T^4 and not \sigma T^4.
This probably also confuses some other people, thanks for pointing out the difference.
Old   November 24, 2017, 10:51
Jean bon
Yes, it confused me at the beginning
Actually, G is not directly the incident radiation even if we call it like that so we have not got:
q_r=G-\sigma T^4
but \nabla . q_r=a(G-4\sigma T^4)
with a the absorption coefficient in m^{-1}
To have the incident radiation, you need the direction because
q_{in}=\int_{one~hemisphere} I(r,s)sd\Omega
And then you have q_r=q_{in}-\sigma T^4
HannesJo, Shub, SamZar and 2 others like this.
Old   November 24, 2017, 10:56
Exactly. It is due to the fact that G is used for the energy balance of a single ray and not of a physical surface. The programmer redefined it a little, but for me knowing G from my lectures and books, it was really confusing.
Radiation boundary condition for fireFoam Marcus Runefors OpenFOAM Running, Solving & CFD 0 September 10, 2015 05:16
simulation radiation and convection taban OpenFOAM Running, Solving & CFD 0 September 6, 2015 03:41
