May 15, 2019, 04:08 |
Bubble rising problem - diverged
John
Rep Power: 7 |
Hello all Foamers !
I'm doing a simulation evolved with bubble rising within a water domain at the moment. I met a serious problem about The Courant number keep bigger and bigger in each time step . Go with it is the max(magU) getting bigger and bigger too. I want to run the case at 200s time step and it diverged at around 2.5s . I just use 90000 hexahedra number of cells , checkMesh is OK , i decrease the timestep even to 1e-10 it still diverged , i turned on the adjustableTimestep but it still had the same problem One more thing I notice that the value of min(alpha1) suddenly decreased from 0 to -1e-9 . And when the value Max cell volume fraction is bigger than 1 with the min dense number of parces = 4 . It diverged immediately Please help me out with this problem.! Below is my checkMesh log, fvSchemes and fvSolution and my boundary condition. Thanks so much for helping me! checkMesh Code:
Mesh stats points: 97061 faces: 276900 internal faces: 263100 cells: 90000 faces per cell: 6 boundary patches: 3 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 90000 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 36 49 ok (non-closed singly connected) outlet 900 961 ok (non-closed singly connected) walls 12864 12936 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.075 -0.075 0) (0.075 0.075 0.5) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-1.25066e-16 -1.31008e-17 1.48292e-18) OK. Max cell openness = 1.35525e-16 OK. Max aspect ratio = 1 OK. Minimum face area = 2.5e-05. Maximum face area = 2.5e-05. Face area magnitudes OK. Min volume = 1.25e-07. Max volume = 1.25e-07. Total volume = 0.01125. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.11023e-13 OK. Coupled point location match (average 0) OK. Mesh OK. Code:
solvers { "alpha.water.*" { nAlphaCorr 2; nAlphaSubCycles 2; cAlpha 1; MULESCorr yes; nLimiterIter 2; solver smoothSolver; smoother symGaussSeidel; tolerance 1e-10;//1e-7; relTol 0; maxIter 100; } pcorr { solver PCG; preconditioner DIC; tolerance 1e-10;//1e-5; relTol 0; } p_rgh { solver PCG; preconditioner DIC; tolerance 1e-10;//1e-07; relTol 0.05; } p_rghFinal { $p_rgh; relTol 0; } "(U|k|epsilon).*" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-10;//1e-06; relTol 0; } kinematicCloud:alpha { solver PCG;//GAMG; tolerance 1e-10;//1e-06; preconditioner DIC;// relTol 0.01; smoother GaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 400; agglomerator faceAreaPair; mergeLevels 1; } } PIMPLE { momentumPredictor no;//yes;//no;//yes;//no; nOuterCorrectors 2; nCorrectors 2; nNonOrthogonalCorrectors 1; pRefCell 0; pRefValue 0; residualControl { "(p|U|k|omega)" { tolerance 1e-4; relTol 0; } } } relaxationFactors { equations { ".*" 0.5 ; } } Code:
ddtSchemes { default Euler;//backward;//Euler;//CrankNicolson 0.38; } gradSchemes { default Gauss linear;//cellLimited Gauss linear 1; //grad(U) Gauss linear;//Gauss linear; // grad(p) Gauss linear;// } divSchemes { default none; div(rhoPhi,U) Gauss upwind; div(phi,alpha) Gauss vanLeer01;//linear;//upwind; div(phirb,alpha) Gauss linear;//interfaceCompression;//linear; div(alphaRhoPhic,k) Gauss upwind; div(alphaRhoPhic,epsilon) Gauss upwind; div((((alphac*rho)*nuEff)*dev2(T(grad(U))))) Gauss linear; div(phiGByA,kinematicCloud:alpha) Gauss linear; } laplacianSchemes { default Gauss linear corrected;//limited corrected 0.1;//uncorrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected;//limited corrected 0.1;//corrected; } fluxRequired { default no; p_rgh; pcorr; alpha.water; } Code:
dimensions [0 0 0 0 0 0 0]; internalField uniform 1; boundaryField { inlet { type zeroGradient; } outlet { type inletOutlet; inletValue uniform 0; value uniform 0; } walls { type zeroGradient; } } Code:
dimensions [ 1 -1 -2 0 0 0 0 ]; internalField uniform 0; boundaryField { inlet { type fixedFluxPressure; value uniform 0; } outlet { type prghTotalPressure; p0 uniform 0; value uniform 0; } walls { type fixedFluxPressure; value uniform 0; } } Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type fixedValue; value uniform (0 0 0); } outlet { type pressureInletOutletVelocity; value $internalField; inletValue $internalField; } walls { type fixedValue; value uniform (0 0 0); } } |
May 15, 2019, 21:24 |
Update
John
Rep Power: 7 |
Update :
I quited control the value of Courant number , but another problem appeared. The value of Phase-1 volume fraction keep increasing in each timestep and when it > 1 and min(alpha1) is negative . The simulation crashed again in ~6s Any idea how to control this value ! Please help me, any advice are really appreciate ! |
TwoPhaseEulerFoam - Bubble diameter size Problem | BlnPhoenix | OpenFOAM Running, Solving & CFD | 8 | September 17, 2019 15:59 |
Taylor bubble rising in vertical pipe | mhb18191 | STAR-CCM+ | 0 | May 14, 2019 15:16 |
rising bubble vof simulation in fluent | vinita123 | Main CFD Forum | 2 | December 21, 2015 07:40 |
bubble rising grid study problem! | mreza_cfd | OpenFOAM Verification & Validation | 7 | July 26, 2015 09:41 |
Coupled VOF and Multiphase Segregated Flow for a gas bubble problem?? | EnronZhang | STAR-CCM+ | 1 | December 19, 2013 08:41 |
