What exactly is h in externalWallHeatFluxTemperature BC?
Like Tree3Likes
  • 2 Post By petr.f.
  • 1 Post By zfaraday
Old   January 16, 2015, 08:24
Default What exactly is h in externalWallHeatFluxTemperature BC?
Petr Furmanek
petr.f. is on a distinguished road
Hi all!
Maybe it is a stupid question, but after looking into the code I'm still a bit confused about true meaning of h in the externalWallHeatFluxTemperature. If I assume the following boundary problem
internal fluid -> wall -> environment
there are two heat transfer coefficients coming into play -
alpha_1 between the internal fluid and the wall and
alpha_2 between the wall and the environment.
So which one of these is h?
petr.f. is offline   Reply With Quote
Old   January 17, 2015, 04:39
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
If you take a look at the sources, here's the way heat flux is calculated:
        case fixedHeatTransferCoeff:
            scalar totalSolidRes = 0.0;
            if (thicknessLayers_.size() > 0)
                forAll (thicknessLayers_, iLayer)
                    const scalar l = thicknessLayers_[iLayer];
                    if (kappaLayers_[iLayer] > 0.0)
                        totalSolidRes += l/kappaLayers_[iLayer];
            q = (Ta_ - Tp)*(1.0/h_ + totalSolidRes);
            break;
Ta_ is ambient temperature, Tp is temperature on the patch. Now, assuming you neglected additional thermal resistance, h can be calculated as
1/h = 1/h_{flud->wall} + 1/h_{wall} + 1/h_{wall->external}
alexeym is offline   Reply With Quote
Old   January 17, 2015, 15:51
Petr Furmanek
Hi Alexey,
thanks for the reply. I'm using OF v 2.3.x with a little bit different code
            hp = 1.0/(1.0/h_ + totalSolidRes);
and then
    else if (mode_ == fixedHeatTransferCoeff)
        Qr /= Tp;
        refGrad() =  0.0;
        refValue() =  hp*Ta_/(hp - Qr);
        valueFraction() =
            (hp - Qr)/((hp - Qr) + kappa(Tp)*patch().deltaCoeffs());
where Qr is radiative heat flux. You're right that from theory the overall hp value is
1/hp = 1/h_{fluid->wall} + 1/h_{wall} + 1/h_{wall->external}
I wasn't sure if there is something neglected in the code or not... So if it isn't then apparently
1/h_{wall} = totalSolidRes
so I presume
1/h_ = 1/h_{fluid->wall} + 1/h_{wall->external}
I suppose I have to estimate the 1/h_{fluid->wall} for example from
as mentioned in https://en.wikipedia.org/wiki/Heat_transfer_coefficient
and then do a similar thing for 1/h_{wall->external} to get the h_ for input of the boundary condition...
Old   January 18, 2015, 04:05
Petr Furmanek
After looking into code of mixedFvPatchScalarField and fluidThermo I think I got it. The h_ is the outer heat transfer coefficient - the 1/h_{wall->external}.
Heat transfer from internal fluid -> wall is solved using the kappa() field, inside the wall with the use of totalSolidRes which leaves the h_{wall->external} to be set by the user.
ksara and vs1 like this.
Old   January 18, 2015, 08:35
Alex
zfaraday will become famous soon enough
Exactly Petr, h is the external heat transfer coefficient, the value of the solid resistance is calculated if you provide values of the kappa layers and thickness layers, otherwise it's neglected.
Regards,
Alex
vs1 likes this.
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   December 26, 2018, 03:14
Jianrui Zeng
calf.Z is on a distinguished road
Regards,
Alex
As usual, should we need the kappalayers and thicknesslayers? What's the meaning of kappalayers (1 2 3 4) and thicknesslayers(0.1 0.2 0.3 0.4)?
calf.Z is offline   Reply With Quote
