BC to use for applying contact angle on a permeable wall in porous media
Old   December 24, 2018, 22:19
Default BC to use for applying contact angle on a permeable wall in porous media
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Hi to all,
I am working on a multiphase model in OpenFoam with two regions i.e., one porous media and the other is fluid.
I am wondering which boundary condition I need to apply for the interface, so I would be able to define contact angle for the permeable wall (interface) and also let the species go through it (permeable wall)?
Please, see the brief schematic below
Thanks,
Abouzar
region 1: gas mixture+ liquid water droplets
------------------------------ permeable wall, I need contact angle here!
region 2: porous media, with porosity, K
Regard yours
A CFD free user is offline   Reply With Quote
Old   December 25, 2018, 09:20
ANKUR GARG
ankur_garg is on a distinguished road
I don't have any experience in Multiphase flow. But I have worked on interface boundary condition. I wanted to ask if you are able to create an interface first and how did you go for it?
Ankur Garg
ankur_garg is offline   Reply With Quote
Old   December 25, 2018, 11:50
A-A Azarafza
Thanks for the response Ankur.
Actually as far as I know, porous media in OpenFoam can be modeled either by defining a porous zone or a porous jump wall. The porous zone properties can be specified either manually through source term or if I am not mistaken, porousInterFoam may be applied. The point is if it is possible to set wettability (contact angle) on the interface or not. I know that it is possible in Fluent but not sure with OpenFoam. Also, is porous jump wall permeable to species transport, say gas mixture?
Regard yours
Old   December 25, 2018, 12:00
ANKUR GARG
Welcome! I just know to model porous media using porous zone not through porous jump wall!
"The porous zone properties can be specified either manually through source term or if I am not mistaken, porousInterFoam may be applied."
Yes, You are Right! I would like to add that porosityProperties can be defined inside constant folder.
Now, Are you able to create interface in your geometry?
Ankur Garg
Old   December 25, 2018, 12:11
A-A Azarafza
I have not tried it yet since depending on the type of the porous media (zone or wall jump), the required mesh would be different. At present, I am trying to get some insights of modeling porous media in OpenFoam. As I told, the only thing is still ambiguous is the possibility of defining contact angle on the interface between fluid and porous zone either by porous media or jump wall.
Have you tried that before, i.e., imposing a contact angle on porous surface?
Regard yours
Old   December 25, 2018, 13:27
ANKUR GARG
I am Sorry, but I have never tried this before (imposing a contact angle on porous surface). But I will ask you to try first creating an interface depending upon any kind of porous problem, then you can think about modeling the porous media. I hope that will be easier, because you will achieve at least first step towards your problem.
Ankur Garg
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
thermal couple boundary condition between porous and fluid regions atoof OpenFOAM Programming & Development 2 June 7, 2017 19:44
how to use UDF or method to define Boundary condition for Porous media in NLTE hitchenxue FLUENT 0 April 19, 2014 02:40
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 15:16
