Running hotRoom tutorial at low pressure causes fatal error "Negative initial temp?" |
January 4, 2019, 14:56 |
Andrew Somorjai
Rep Power: 13 |
Hello all,
I would love an explanation as to why this isn't functioning. I've looked over the theory of why this solver runs and I still cannot imagine why I'd get a negative temperature for the initial case. Here's the output of the error running the hotRoom tutorial with buoyantPimpleFoam Code:
Courant Number mean: -6.65662e-05 max: 4.57604e-07 Time = 3e-07 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 DILUPBiCGStab: Solving for Ux, Initial residual = 0.00268968, Final residual = 4.59223e-15, No Iterations 1 DILUPBiCGStab: Solving for Uy, Initial residual = 0.00269014, Final residual = 4.60139e-15, No Iterations 1 DILUPBiCGStab: Solving for Uz, Initial residual = 0.00268968, Final residual = 4.59223e-15, No Iterations 1 DILUPBiCGStab: Solving for h, Initial residual = 0.19232, Final residual = 1.63083e-12, No Iterations 1 --> FOAM FATAL ERROR: Negative initial temperature T0: -91630.1 From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam::perfectGas<Foam::specie> >; Type = Foam::sensibleEnthalpy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy>] in file /mnt/external/OpenFOAM/OpenFOAM-v1806/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 54. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, bool) at ??:? #3 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::correct() at ??:? #4 ? in /mnt/external/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/bin/buoyantPimpleFoam #5 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #6 ? in /mnt/external/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/bin/buoyantPimpleFoam blockMesh setFields foamJob -s buoyantPimpleFoam The machines file is obviously my machine so you may need to change that to run it. I attached the entire case as a zip hotRoom.zip I only made changes to the pressure files, here's p Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1806 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1e2; boundaryField { floor { type calculated; value $internalField; } ceiling { type calculated; value $internalField; } fixedWalls { type calculated; value $internalField; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1806 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1e2; boundaryField { floor { type fixedFluxPressure; value $internalField; } ceiling { type fixedFluxPressure; value $internalField; } fixedWalls { type fixedFluxPressure; value $internalField; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1806 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application buoyantPimpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 2000; deltaT .0000001; writeControl timeStep; writeInterval 100; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; adjustTimeStep no; maxCo 0.5; // ************************************************************************* // |
January 5, 2019, 02:32 |
Peter Baskovich
Rep Power: 11 |
Do you want to know why this is happening or just how to fix it? I can suggest utilising the limitTemperature function in fvOptions with some reasonable limits. Your issue is likely that the initial conditions are either bad or non-physical, although I have heard of parallel sometimes affecting convergence, although I think that was a bug and not normal behaviour.
https://www.openfoam.com/documentati...mperature.html Or try initialising with a steady-state solver. (Sorry for the long link, I'm on my phone) |
January 5, 2019, 13:09 |
#3 | |
Andrew Somorjai
Rep Power: 13 |
PIMPLE { momentumPredictor yes; nOuterCorrectors 1; nCorrectors 2; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 1e2; } I changed the pRefValue from 1e5 to the one shown above and then in object p_rgh I changed to this internalField uniform 1e1; and also in object p to internalField uniform 1e2; and the timestep is deltaT .0000001;. These changes made it work. Not positive if this is the best fix; ran it for a while but at small timesteps, not sure if running it at 1/1000th would still work but that would be ideal. If you want to explain the theory why the solver got negative temperature that would be fine. I would like to read your explanation. Thanks! |
buoyantpimplefoam, fatal error, low pressure, negative temperature |
decompose dependent solution | arionfard | OpenFOAM | 3 | December 10, 2018 09:36 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 22:13 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
