Rough wall boundary condition for laminar flow
Old   February 4, 2019, 04:36
Default Rough wall boundary condition for laminar flow
Robert
RobertHB is on a distinguished road
Dear Foamers,
I'm doing laminar flow simulations in the Stokes regime (Re << 1). Currently my rectangular box chaped domain has smooth walls treated with fixedValue boundary conditions.
For a next set of simulations i want to test the influence of various wall roughness factors on the flow. I know there is the nutURoughWallFunction treat nut at the walls but this requires the use of a turbulence model. Given the nature of my flow the use of a turbulence model just to calculate nut is of not much use as my turbulence variables range around e-10. But this seems to be the only way to implement some rough wall treatment.
Do you consider this to be the right approach? Are there different methods for implementing wallroughness in laminar flows in OpenFoam?
Cheers
Robert
If you liked my answer to your question, please consider leaving a "Like" in return
RobertHB is offline   Reply With Quote
Old   February 6, 2019, 14:58
wildfire230 is on a distinguished road
I wonder if there is a way to add a random "kick" normal to the surface to each of the grid points with a distribution about your roughness of interest?
By the way, what solver are you using for the Stokes regime? simpleFoam? I am actually working on a related problem using a slightly modified simpleFoam where I simply deleted the convection term in the equation. I'm a little unclear about boundary conditions because zeroGradient seems definitely inappropriate for the pressure, but I'm not really sure what's better.
Best regards
wildfire230 is offline   Reply With Quote
Old   February 7, 2019, 03:38
Robert
I'm using simpleFoam with the turbulence model set to laminar. Haven't thought to much about BC's because i do not care for the pressure field. And the velocity field matches perfectly with the analytical solution.
boundary condition, laminar flow, wall roughness
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 05:53
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 01:44
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
