FOAM FATAL IO ERROR:file: unknown
Old   January 31, 2023, 07:14
Default FOAM FATAL IO ERROR:file: unknown
Yateng Qiao
YatengQ is on a distinguished road
Hi everyone,
I use the dynamic mesh according to the propeller tut. When I use the command: decomposePar. The processor folder does not contain 0 folder.(I use ICEM mesh converted by fluentMeshtoFoam) There is an error list as follows:
Create time
Decomposing mesh region0
Reading "decomposeParDict"
Create mesh
Calculating distribution of cells
Selecting decompositionMethod hierarchical
Finished decomposition in 0.89 s
Calculating original mesh data
Distributing cells to processors
Distributing faces to processors
Distributing points to processors
Constructing processor meshes
Processor 0
Number of cells = 204363
Number of faces shared with processor 1 = 14384
Number of processor patches = 1
Number of processor faces = 14384
Number of boundary faces = 19174
Processor 1
Number of faces shared with processor 0 = 14384
Number of faces shared with processor 2 = 14224
Number of processor patches = 2
Number of processor faces = 28608
Number of boundary faces = 4952
Processor 2
Number of faces shared with processor 1 = 14224
Number of faces shared with processor 3 = 13379
Number of processor faces = 27603
Number of boundary faces = 6687
Processor 3
Number of faces shared with processor 2 = 13379
Number of faces shared with processor 4 = 14264
Number of processor faces = 27643
Number of boundary faces = 8107
Processor 4
Number of faces shared with processor 3 = 14264
Number of faces shared with processor 5 = 14376
Number of processor faces = 28640
Number of boundary faces = 4908
Processor 5
Number of faces shared with processor 4 = 14376
Number of faces shared with processor 6 = 14223
Number of processor faces = 28599
Number of boundary faces = 5137
Processor 6
Number of faces shared with processor 5 = 14223
Number of faces shared with processor 7 = 14384
Number of processor faces = 28607
Number of boundary faces = 4953
Processor 7
Number of cells = 204369
Number of faces shared with processor 6 = 14384
Number of processor faces = 99234
Max number of cells = 204369 (0.00256895% above average 204364)
Max number of processor patches = 2 (14.2857% above average 1.75)
Max number of faces between processors = 28640 (15.4443% above average 24808.5)
Time = 0
--> FOAM FATAL IO ERROR:
file: unknown
I cant find where the problem is.
YatengQ is offline   Reply With Quote
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 11:32
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 02:21
Incompatible dimensions for operation ruben23 OpenFOAM Running, Solving & CFD 2 June 12, 2015 04:14
decomposePar is missing a library whk1992 OpenFOAM Pre-Processing 8 March 7, 2015 07:53
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
