Howto get the production and dissipation of TKE??
Like Tree3Likes
  • 1 Post By lakeat
  • 1 Post By johndeas
  • 1 Post By alberto
Old   June 27, 2009, 04:44
Question Howto get the production and dissipation of TKE??
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Anyone knows how to get the production and dissipation of TKE (turbulence kinetic energy)? Thanks
Is it in this way:
        volSymmTensorField D = symm(fvc::grad(U));
        //volTensorField Dprim = symm(fvc::grad(U - UMean));
        volScalarField prod = -((U - UMean)*(U - UMean)) && D;
        volScalarField epsilon = sgsModel->epsilon();
  • Rate of production of turbulence kinetic energy from the mean flow(gradient): - \left\langle u_{i}u_{j} \right\rangle \frac{\partial U_{i}}{\partial x_{j}}
  • Rate of dissipation of turbulence kinetic energy per unit mass due to viscous stresses: \epsilon \equiv 2\nu \left\langle s_{ij}s_{ij} \right\rangle
cagri.metin.ege likes this.
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   July 6, 2010, 10:55
Default Production and dissipation of TKE
Heesei is on a distinguished road
Dear Daniel
I am also interested in this topic. Therefore, I would like to know if you found an answer to your question in the meantime.
Cheers,
Irina
Heesei is offline   Reply With Quote
Old   July 6, 2010, 11:26
lakeat's Avatar
Daniel WEI (老魏)
Sorry, it'e been a long time, but doesn't the codes in my last post work for you?
you can try with a channel case and see if its distribution is correct.
Bye
Daniel WEI
Beijing, China
Email
Old   December 13, 2010, 17:51
John Deas
johndeas is on a distinguished road
why did you take the symmetrical part of grad(U) ? Why didn't you compute
R && fvc::grad(Umean)
Regards,
JD
johndeas is offline   Reply With Quote
Old   December 14, 2010, 03:55
Alberto Passalacqua
Notice that the method epsilon() returns the SGS dissipation rate. Check doxygen to see how it is computed, depending on the specific model.
Alberto Passalacqua
Old   December 14, 2010, 08:18
John Deas
Hi Alberto,
thank you for your answer. When I take a look at src\turbulenceModels\LES\incompressible\oneEqEddy\ oneEqEddy.C, I read:
void oneEqEddy::correct(const tmp<volTensorField>& gradU)
    GenEddyVisc::correct(gradU);
    volScalarField G = 2.0*nuSgs_*magSqr(symm(gradU));
    solve
       fvm::ddt(k_)
     + fvm::div(phi(), k_)
     - fvm::laplacian(DkEff(), k_)
       G
     - fvm::Sp(ce_*sqrt(k_)/delta(), k_)
    bound(k_, k0());
    nuSgs_ = ck_*sqrt(k_)*delta();
    nuSgs_.correctBoundaryConditions();
it appears that, in src\turbulenceModels\LES\incompressible\GenEddyVis c\GenEddyVisc.H (for example), epsilon() represents
. But, what I am interrested in is G, the production. Since I am doing DNS computations, I have access to both the Reynolds Stress and the gradient of the mean component of velocity, and I do not want to use any eddy viscosity to compute it, like in
. I just need the formula to combine R and fvc::grad(Umean) properly.
I also do not understand why the symmetric part of the gradient of U is mentionned in the previous post.
Regards,
JD
manuc likes this.
Old   December 14, 2010, 09:34
David Boger
boger is on a distinguished road
The double-inner product of a symmetric and asymmetric second-rank tensor is zero, so in that sense, only the symmetric part of gradU "survives" anyway. So using only the symmetric part is harmless, but perhaps unnecessary.
David A. Boger
boger is offline   Reply With Quote
Old   December 14, 2010, 11:21
Alberto Passalacqua
Originally Posted by johndeas View Post
Hi Alberto,
    solve
       fvm::ddt(k_)
       G
    bound(k_, k0());
My comment was to point out that
does not return what you want. That epsilon is only the SGS epsilon.
Since you do DNS, just apply the definition and you will be fine :-)
Best,
solefire likes this.
Alberto Passalacqua
Old   July 9, 2016, 04:56
Syavash Asgari
syavash is on a distinguished road
This is an old thread, but I wonder if anyone has achieved a reliable method to calculate TKE dissipation?!
Regards
syavash is offline   Reply With Quote
Old   March 22, 2022, 11:14
nukecrafts is on a distinguished road
Hi Alberto,
    solve
       fvm::ddt(k_)
       G
    bound(k_, k0());
Regards,
JD
Dear Johndeas,
Did you find any way out ? I'm also stuck at the same state.
nukecrafts is offline   Reply With Quote
Turbulent Dissipation Rates - epsilon Otute Main CFD Forum 5 May 20, 1999 10:51
