March 12, 2019, 07:29 |
OpenFOAM simulation crash
Rasmus Iwersen
Rep Power: 8 |
Hi all,
I am trying to run an oscillatingPimpleFoam simulation on a simple geometry. Depending on the mesh refinement, the simulation crashes (I have tried with different Co numbers ranging between 150 and 3). Is there a way to control the Co number (changing deltaT does not change a thing)? I assume the crash is caused by the too high Co number, as a more coarse mesh runs just fine. Thank you for your help! |
March 13, 2019, 10:12 |
anonymous
Rep Power: 14 |
hi!
Add these to your controlDict or modify if present: adjustTimeStep yes; maxCo 0.9; 150 Co is HUGE! With PIMPLE you can go up to like 5-10, or if your case is hell stable maybe more, but if you can try to keep Co under 1 for stability and accuracy purposes. |
March 13, 2019, 10:24 |
Rasmus Iwersen
Rep Power: 8 |
Thank you so much for your reply! I have admitted defeat, and tried my luck with SnappehexMesh instead. For some reason the gmsh mesh caused extreme instability. I don't know if it was because my model had very sharply defined edges (which is where i assume the cells with large Co is located), or what the reason was.
Nevertheless, with SnappyHexMesh i succeeded in getting the model to act a lot more stable. |
crash, mesh, openfoam |
OpenFoam crash with dynamicMesh, cyclicAMI and MPI DAPL UD | aendres | OpenFOAM | 5 | February 25, 2019 05:18 |
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days | joegi.geo | OpenFOAM Announcements from Other Sources | 0 | October 1, 2016 19:20 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
diesel Engine simulation in OpenFOAM | karam | OpenFOAM Running, Solving & CFD | 1 | March 1, 2011 09:46 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
