February 24, 2022, 14:05 |
keyword RASModel is undefined in dictionary
Rep Power: 4 |
I'm trying to run a simulation using the pisoFoam solver with OpenFOAM 8, however I'm getting the following error: Code:
--> FOAM FATAL IO ERROR: keyword RASModel is undefined in dictionary "/home/harvyp/OpenFOAM/harvyp-8/run/TestCase2/constant/turbulenceProperties.RAS" file: /home/harvyp/OpenFOAM/harvyp-8/run/TestCase2/constant/turbulenceProperties.RAS from line 22 to line 26. From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const in file db/dictionary/dictionary.C at line 570. FOAM exiting Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object turbulenceProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // simulationType RAS; RAS { model kEpsilon; turbulence on; printCoeffs on; } // ************************************************************************* // Many thanks. |
February 27, 2022, 13:15 |
Rep Power: 14 |
Try change:
model kEpsilon; Code:
RASModel kEpsilon; |
April 12, 2023, 08:22 |
ghita
Thank you so much , i had this problem and your post helped me solve it
LEMOS InflowGenerator | r_gordon | OpenFOAM Running, Solving & CFD | 103 | December 18, 2018 00:58 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
