OpenFOAM, Difference between combustion and reaction |
March 30, 2019, 14:22 |
Farshad
Rep Power: 15 |
Hi;
Can any one explain the differences between following codes, bold lines: Code:
forAll(Y, i) { if (i != inertIndex && composition.active(i)) { volScalarField& Yi = Y[i]; fvScalarMatrix YiEqn ( fvm::ddt(rho, Yi) + mvConvection->fvmDiv(phi, Yi) - fvm::laplacian(turbulence->muEff(), Yi) == reaction->R(Yi) + fvOptions(rho, Yi) ); YiEqn.relax(); fvOptions.constrain(YiEqn); YiEqn.solve(mesh.solver("Yi")); fvOptions.correct(Yi); Yi.max(0.0); Yt += Yi; } } Code:
forAll(Y, i) { if (i != inertIndex && composition.active(i)) { volScalarField& Yi = Y[i]; fvScalarMatrix YiEqn ( fvm::ddt(rho, Yi) + mvConvection->fvmDiv(phi, Yi) - fvm::laplacian(turbulence->alphaEff(), Yi) == parcels.SYi(i, Yi) + surfaceFilm.Srho(i) + combustion->R(Yi) + fvOptions(rho, Yi) ); YiEqn.relax(); fvOptions.constrain(YiEqn); YiEqn.solve(mesh.solver("Yi")); fvOptions.correct(Yi); Yi.max(0.0); Yt += Yi; } } |
March 31, 2019, 12:16 |
Rep Power: 14 |
There shouldn't be any difference. If you check the respective create fields, you'll notice one creates names the combustion autoPtr "combustion" and the other names it "reaction".
Caelan |
March 31, 2019, 15:42 |
Farshad
Rep Power: 15 |
Dear Caelan, thanks for your answer.
You are right. I quote both of the pointer definitions below for future users who may follow this thread: Code:
autoPtr<CombustionModel<psiReactionThermo>> reaction ( CombustionModel<psiReactionThermo>::New(thermo, turbulence()) ); Code:
autoPtr<CombustionModel<psiReactionThermo>> combustion ( CombustionModel<psiReactionThermo>::New(thermo, turbulence()) ); |
March 31, 2019, 17:49 |
Rep Power: 14 |
In brief, fireFoam tutorials are all configured to use infinitelyFast chemistry. To use other combustion models you'll likely need to provide some sort of energy source (eg a spark or a pilot flame or preheating reactants) to start reactions. Look into the reactingFoam tutorials for examples for how to do this. However, then you'll need to start thinking about the nature of your combustion problem -- for mixing controlled diffusion flames the infinitely fast assumption is not a terrible one. That said, there are extensions of the EDC to les that do modify the infinitely fast heat release by local laminar/turbulence timescales (see e.g. https://www.sciencedirect.com/scienc...79711214000125). I think the OpenFoam+ side has a variant of this.
Caelan |
April 1, 2019, 01:49 |
Farshad
Rep Power: 15 |
I used energy sources (e.g ignition by setFields and fvSolution) but nothing changed.
I am going to try extended version of OF, maybe I could find the solution. p.s: results of infinitelyFast are not reliable comparing with experiments for pool fire. |
April 1, 2019, 10:42 |
Rep Power: 14 |
If you change the combustion model, you will need to make corresponding changes to the thermo/reactions. Re. infinitely fast, it may not work out of the box. As I said, extension to the eddy dissipation model works quite well. See eg. https://www.sciencedirect.com/scienc...10002944#b0005.
Caelan |
combustion model, openfoam6 |
How to switch off combustion and reaction in reactingFoam | shenzhou1987 | OpenFOAM Running, Solving & CFD | 16 | October 26, 2017 15:31 |
Detailed Chemical reaction over combustion model | jaychhatbar | AVL FIRE | 1 | June 23, 2017 13:13 |
how to add the ion reaction to the combustion mechanism in Chemkin Pro | dfzw_jwd | Main CFD Forum | 0 | December 1, 2016 03:30 |
Coal combustion and ash reaction kinetics | sega | Fluent UDF and Scheme Programming | 0 | January 21, 2010 08:05 |
combustion - reaction rates - urgent help needed | siri | Main CFD Forum | 2 | March 3, 2007 12:25 |
