Fvoption
Old   April 11, 2019, 15:59
Default Fvoption
Raza Javed
Raza Javed is on a distinguished road
Hello everyone,
I read about fvoption framework but not able to understand the basic functionality. I read that it is used to generate the source terms e.g heat source etc.
What is meant by source terms?
As I read we can also mention power as an input in it while using as a heat source. For example if my geometry has a heat source to heat up the fluid. But I just know the power dissipation of that heat source.
Can I use this power to put into the fvoption to generate heat as the output of this heat source? And that heat will be used to raise the temperature of the fluid.
Does it work like this or something else?
Any help would be highly appreciated.
Thank you
Raza Javed is offline   Reply With Quote
boundaries condition, fvoption, heat source term, openfoam
[swak4Foam] swak4foam for fe40: fvOption library don't compile? jf_vt OpenFOAM Community Contributions 7 August 10, 2023 03:00
reactingFoam fvOption ignition khalifa OpenFOAM Programming & Development 8 January 6, 2019 18:45
fvOption - pressureGradient gu1 OpenFOAM Pre-Processing 0 October 18, 2018 21:39
fvOption interpolation scheme aghsin OpenFOAM Running, Solving & CFD 0 June 25, 2016 09:01
fvoption MRF on solid micpage18 OpenFOAM Running, Solving & CFD 0 January 22, 2014 14:47
