"Segmentation fault" when using reconstructPar and renumberMesh
Like Tree1Likes
  • 1 Post By reza2031
Old   April 24, 2019, 17:06
Default "Segmentation fault" when using reconstructPar and renumberMesh
Reza Nouri
reza2031 is on a distinguished road
Send a message via Skype™ to reza2031
Here is the issue:
I have installed OF 2.40 on a Centos 7 system (as a user not administrator). I followed the instruction on wiki:
https://openfoamwiki.net/index.php/I...CentOS_SL_RHEL
Everything compile fine and it seems everything works, but when it comes to using reconstructPar or renumberMesh, I get "segmentation fault" error:
I ran the cavity case (incompressible laminar flow) using 2 processors. It ran successfully, but when I type reconstructPar, I get this error:
|  \\    /   O peration     | Version:  2.4.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.4.0-dcea1e13ff76
Exec   : reconstructPar
Date   : Apr 24 2019
Time   : 15:48:31
Host   : "gpunode001"
PID    : 147305
Case   : /home/tntech.edu/rnouri42/OpenFOAM/OpenFOAM-2.4.0/tutorials/incompressible/icoFoam/cavity
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Reconstructing fields for mesh region0
Time = 0.1
Reconstructing FV fields
    Reconstructing volScalarFields
        p
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigSegv::sigHandler(int) at ??:?
#2  ? in "/lib64/libc.so.6"
#3  Foam::fvPatchField<double>::addpatchMapperConstructorToTable<Foam::zeroGradientFvPatchField<double> >::New(Foam::fvPatchField<double> const&, Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::fvPatchFieldMapper const&) at ??:?
#4  ? at ??:?
#5  ? at ??:?
#6  ? at ??:?
#7  ? at ??:?
#8  ? at ??:?
#9  __libc_start_main in "/lib64/libc.so.6"
#10  ? at ??:?
Segmentation fault
And for renumberMesh, I get:
Exec   : renumberMesh
Date   : Apr 24 2019
Time   : 15:52:53
Host   : "gpunode001"
PID    : 149066
nProcs : 1
Create time
Create mesh for time = 0
Mesh size: 400
Before renumbering :
    band           : 20
    profile        : 7619
Using default renumberMethod.
Selecting renumberMethod CuthillMcKee
Reading volScalarField p
Reading volVectorField U
#3  Foam::polyMesh::resetPrimitives(Foam::Xfer<Foam::Field<Foam::Vector<double> > > const&, Foam::Xfer<Foam::List<Foam::face> > const&, Foam::Xfer<Foam::List<int> > const&, Foam::Xfer<Foam::List<int> > const&, Foam::List<int> const&, Foam::List<int> const&, bool) at ??:?
#4  ? at ??:?
#5  ? at ??:?
#6  __libc_start_main in "/lib64/libc.so.6"
#7  ? at ??:?
Segmentation fault
On my laptop with the same OF version and case, it works fine. But on HPC something is not correct and I am struggling to find the answer.
Any idea?
Thank you.
Reza
reza2031 is offline   Reply With Quote
Old   April 25, 2019, 21:40
Reza Nouri
Just for the record,
I solved the issue by installing another version of OpenFOAM (2.3.1 instead of 2.4.0).
Reza
nishant.kumar likes this.
[mesh manipulation] Some questions on blockMesh, decomposePar and renumberMesh Leech OpenFOAM Meshing & Mesh Conversion 19 April 5, 2019 19:21
renumberMesh pere OpenFOAM 4 May 9, 2012 08:52
