May 7, 2019, 01:08 |
Creating a spherical domain
Tanvi
Rep Power: 7 |
Hello!
I would like to know how to initialise a spherical domain and give the input values in OpenFOAM. It would be of great help if someone could suggest some idea or the procedure or any documentation related to it. Thank You. |
May 7, 2019, 09:33 |
Fumiya Nozaki
Rep Power: 18 |
You can use the setFields utility to set values on a selected set of cells. For selecting a spherical domain you can use the sphereToCell option: https://github.com/OpenFOAM/OpenFOAM.../setFieldsDict Hope this helps, Fumiya
[Personal]
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[Other] How to correctly mesh a spherical domain with an .stl objet in it ? | TerenceA | OpenFOAM Meshing & Mesh Conversion | 3 | September 14, 2017 09:00 |
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation | volleyHC | CFX | 5 | April 3, 2016 05:41 |
Problem with creating a domain in hexpress | glasgow_andrew | Fidelity CFD | 2 | March 11, 2014 12:04 |
How to access user defined materials when creating solid domain? | 0906536m | CFX | 3 | September 26, 2013 18:41 |
