May 20, 2019, 10:00 |
Running chtMultiRegionFoam
Arslan Adeel Ur Rehmann
Rep Power: 7 |
Hi. I am trying to run some chtMultiRegion Simulations. Every tutorial follows as below:
blockMesh topoSet sliptMeshRegion run Application this is because they normally have one Mesh and then split them into MultiRegions. However, in my case I already have two separate meshes, one for solid region and one for fluid region, I just put them into their respective constant/ploymesh directory and I am not using topoSet and splitMeshRegion commands. My check Mesh is ok on individual Meshes. however when I run the checkMesh on the same meshes in Multiregion case directory it fails. I don't know whether the procedure I am doing is ok. Or I should try some other things. |
May 28, 2019, 11:01 |
Your question is wide open and it may have many possibilities
Couple of questions. How did you mesh? Can you please post your "boundary" file from respective polyMesh folder? What error do you get? Regards |
#chtmultire #twomesh |
Problem with running chtMultiRegionFoam after using setSet utility | Victor | OpenFOAM | 12 | March 24, 2023 00:01 |
Error in chtMultiRegionFoam | michael157 | OpenFOAM Running, Solving & CFD | 17 | May 22, 2017 03:32 |
Error in running case in chtMultiRegionFoam | baran_foam | OpenFOAM Programming & Development | 3 | July 7, 2015 04:38 |
Hypersonic Sim (running at Mach 7): floating point exception has occurred | bungusbeefcake | STAR-CCM+ | 10 | March 31, 2015 06:59 |
Fluent 14.0 file not running in parallel mode in cluster | tejakalva | FLUENT | 0 | February 4, 2015 07:02 |
