July 2, 2019, 08:38 |
Cube root in OpenFOAM
Rep Power: 6 |
Hello everyone,
Does anyone knows how to put cube root in OpenFOAM? |
July 5, 2019, 08:59 |
Yes, this is quite straightforward. Knowing that we can calculate the square root of something e.g. x with :
sqrtX = sqrt(x) Code:
cbrtX = cbrt(x) Code:
cbrtX = pow(x,1.0/3.0) |
July 5, 2019, 09:42 |
Rep Power: 6 |
Thanks a lot!
July 5, 2019, 09:43 |
Rep Power: 8 |
For a more safe result (including negative numbers) you can use the following:
// calculate the cube root of abs(x) cbrtAbsX = pow(abs(x), 1.0/3.0) // the cube root is returned according to the sign of x cbrtX = (x < 0)? -cbrtAbsX:cbrtAbsX |
July 5, 2019, 10:24 |
Rep Power: 6 |
Thanks for the suggestion!
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
[snappyHexMesh] snappyHexMesh on sharp corners (cube) | Regis_ | OpenFOAM Meshing & Mesh Conversion | 0 | June 4, 2015 23:47 |
[OpenFOAM.org] How to get OpenFoam compiled on a cluster with CentOS 6.5 and no root permissions | hulli | OpenFOAM Installation | 2 | November 6, 2014 18:01 |
Environment errors with .deb install and ubuntu 13.04 64 bit | jonathanbyrn | OpenFOAM Installation | 14 | September 26, 2013 05:22 |
