Simulate particle/liquid flow in a converging geometry with MPPICFoam
Like Tree1Likes
  • 1 Post By minzhang
Old   May 23, 2018, 19:02
Default Simulate particle/liquid flow in a converging geometry with MPPICFoam
Min Zhang
minzhang is on a distinguished road
Hello All,
This is Min, a Ph.D. in Petroleum Engineering.
I have been working on MPPICFoam during the past 3 months.
My focus is to apply MPPICFoam to simulate particle/liquid transport in the wellbore (a cylinder) with a perforation (it is a constricted geometry compared with the wellbore).
Please look at the attachment for the detailed geometry information.
Boundary conditions could be like this:
Inlet: fixed velocity pointing into the cylinder;
Outlet: fixed pressure (P=0);
Perforation: fixed velocity pointing out of the cylinder, which means the particle&liquid would flow outside through the perforation, which is exactly the source of the simulation problem.
Our simulation case has a wide solid/particle volume fraction range (from assumed even spatial distribution near the inlet, which can be 0-20%, to dense flow near the perforation (the constricted area), which can be 40-60+%)
Our Reynolds number could be 1e6, even 1e7, so it is a turbulent flow.
Then, I find that it is very difficult for MPPICFoam to handle the situation where the perforation fluid velocity is larger.
The error message is, the max. particle volume fraction is larger than 1 and then it crashes.
Q1: I set the packing limit to be 0.6, I don't know why the particle volume fraction could be larger than 0.6, even larger than 1.
Q2: When the perforation fluid velocity is small, MPPICFoam could handle this problem and the results could match experimental data very well. But if the perforation velocity is larger, then it means, the fluid will drive more particles to come to this constricted area simultaneously, then MPPICFoam will crash. Why? Compared with the dilute flow, MP-PIC should be more appropriate for the dense flow, yes?
Q3: I think I need to look into the source code to figure out why MPPICFoam could calculate a particle volume fraction larger than packing limit, even larger than 1, which is unphysical. But I don't know where to start?
Any comments and suggestions would be very very appreciated!
Thanks and best regards,
Min
kk2017 likes this.
minzhang is offline   Reply With Quote
Old   May 25, 2018, 10:39
Min Zhang
Hello All,
I am still waiting for your valuable answers/comments/suggestions!
FYI, I think this related paper is worth reading.
Assessment of Different Discrete Particle Methods Ability To Predict
Gas-Particle Flow in a Small-Scale Fluidized Bed
Liqiang Lu,† Balaji Gopalan,†,‡ and Sofiane Benyahia*,†
Old   June 26, 2018, 15:20
hellollq@qq.com is on a distinguished road
Originally Posted by minzhang View Post
Hello All,
Min
If I were you, I'll try the same condition in a rectangle to check if the problem is caused by CFD grid.
hellollq@qq.com is offline   Reply With Quote
Old   July 3, 2018, 00:20
Min Zhang
Hello llq,
Thank you so much for your reply! Very appreciate!
I am wondering why you think I could use a rectangle instead of a cylinder to check where the problem is. I'm sorry I can't get your point. I am wondering whether you could explain more.
Min
Old   August 2, 2019, 17:35
Utkan Caliskan
dscian is on a distinguished road
Which version are you using, .com or .org?
dscian is offline   Reply With Quote
port flow analysis in internal combustion engine , rhosimpleFoam NOT converging gian93 OpenFOAM Running, Solving & CFD 3 November 7, 2017 02:55
Solving complex geometry with compressible flow gfoam FLUENT 1 May 19, 2017 14:56
How to simulate dilute solid particles in gas flow? chpjz0391 OpenFOAM Running, Solving & CFD 4 March 22, 2016 19:32
kOmegaSST without turbulence modelling of the flow around geometry CFDnewbie147 OpenFOAM Running, Solving & CFD 7 December 5, 2013 07:29
how to simulate orifice in supersonic flow? YING FLUENT 2 May 16, 2013 10:41
