niewiemnic
Rep Power: 8 ![]() |
Hi
I simulated a case without problem in a computer, in which only Ubuntu 1804 was installed. But if I copy the case files to a windows 10 computer and simulate the same thing, there is always this error message... I installed the Ubuntu in Windows 10 in this way "https://www.openfoam.com/download/install-windows-10.php". How can I solve this problem? /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v1906 OPENFOAM=1906 Arch : "LSB;label=32;scalar=64" Exec : pimpleFoam Date : Aug 05 2019 Time : 20:57:38 Host : PID : 6020 I/O : uncollated Case : /mnt/c/Users/USER/Downloads/kanal nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From function bool Foam::IOobject::readHeader(Foam::Istream&) in file db/IOobject/IOobjectReadHeader.C at line 114 Reading "/mnt/c/Users/USER/Downloads/kanal/system/controlDict" at line 1 First token could not be read or is not the keyword 'FoamFile' Check header is of the form: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // |
Could you post your controlDict file?
niewiemnic
Thank you for your answer, I post the controlDict.
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application pimpleFoam; startFrom startTime; startTime 3.2; stopAt endTime; endTime 5.0; deltaT 0.0025; writeControl runTime; writeInterval 0.2; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; functions { Q1 { type Q; libs ("libfieldFunctionObjects.so"); writeControl writeTime; } vorticity1 { type vorticity; libs ("libfieldFunctionObjects.so"); writeControl writeTime; } yPlus { type yPlus; libs ("libfieldFunctionObjects.so"); writeControl writeTime; } Lambda2 { type Lambda2; libs ("libfieldFunctionObjects.so"); writeControl writeTime; field U; } div1 { type div; libs ("libfieldFunctionObjects.so"); writeControl writeTime; field Lambda2; } fieldAverage1 { type fieldAverage; libs ("libfieldFunctionObjects.so"); writeControl writeTime; timeStart 0.3; fields ( U { mean on; prime2Mean on; base time; } p { mean on; prime2Mean on; base time; } Lambda2 { mean on; prime2Mean off; base time; } div(Lambda2) { mean on; prime2Mean off; base time; } ); } } // ************************************************** *********************** // |
Your controlDict is OK. But I think the problem is somewhere else with other files.
Yann
Rep Power: 27 ![]() |
Another idea: it might be related to linux/windows line endings issues. Have you edited your controlDict in windows? And if yes, with which software? You can use vi right from the terminal to check if your controlDict file is ok, or use an editor such as Notepad++ on windows. (Open your file in notepad++, then "edit/EOL Conversion". It should be set to "Unix") |
niewiemnic
@Evren Linda: OpenFOAM version is v1906 and I checked that all the files have a header.
@Yann: Thank you for your idea, but with vi and notepad++ it doesnt work. |
Yann
What do you mean it doesn't work?
niewiemnic
I can still see the same error messages like what I posted yesterday.
#9 |
niewiemnic
I just recognised that simpleFoam and icoFoam work well. Hymm, what can be the reason for this problem...? My solver is pimpleFoam.
#10 |
Yann
I'm pretty sure I faced this error before but I can't remember what it was.
Could you elaborate about what you tried? Have you tried to run icoFoam and simpleFoam on your case or on another case/tutorial? Have you tried to run pimpleFoam on a tutorial? When you run your case on your windows system, do you run it from scratch or restart the case from a previously saved time step? |
#11 |
niewiemnic
@Yann
Thank you for your answer once more. 1.Have you tried to run icoFoam and simpleFoam on your case or on another case/tutorial? - I just started two tutorials with icoFoam and simpleFoam, not my case. 2. Have you tried to run pimpleFoam on a tutorial? - After that I read your answer, I started a simulation of tutorial channel395. The simulation for channel 395 works well with pimpleFoam! 3. When you run your case on your windows system, do you run it from scratch or restart the case from a previously saved time step? - I installed my ubuntu 18.04 LTS from https://www.microsoft.com/de-de/p/ub...ot:overviewtab ... and I restarted the case from a previously saved time step (t=3.2 s) as I posted two days ago. |
#12 |
Yann
Then the error is most probably related to your case.
I suggest to narrow down the potential issues by restarting your case (or a copy) from scratch, as you did the first time on your other computer. If you still get the error, try to simplify your case, for instance by deleting the functionObjects, until it works or until you can identify where does the error come from. |
#13 |
niewiemnic
@Yann
The problem is solved! I installed "make", sudo apt-get install make and it works well! |
#14 |
niewiemnic
| ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v1906 OPENFOAM=1906 Arch : "LSB;label=32;scalar=64" Exec : pimpleFoam Date : Aug 07 2019 Time : 15:46:31 Host : USER PID : 0000 I/O : uncollated Case : /mnt/c/Users/USER/OpenFOAM/USER-v1906/run/kanal/re_tau_180_wale nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 3.2 PIMPLE: max iterations = 20 field p : relTol 0, tolerance 1e-05 field U : relTol 0, tolerance 1e-05 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type LES Selecting LES turbulence model WALE Selecting LES delta type cubeRootVol LES { LESModel WALE; turbulence on; printCoeffs on; delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } PrandtlCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } Cdelta 0.158; } vanDriestCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } Aplus 26; Cdelta 0.158; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } Ce 1.048; Ck 0.094; Cw 0.325; } No MRF models present Creating finite volume options from "constant/fvOptions" Selecting finite volume options type meanVelocityForce Source: momentumSource - selecting all cells - selected 1081344 cell(s) with volume 40.96 Reading pressure gradient from file Initial pressure gradient = 0.26874 Courant Number mean: 0.720607 max: 0.799872 Starting time loop fieldAverage fieldAverage1: Restarting averaging for fields: U: starting averaging at time 3.2 p: starting averaging at time 3.2 Lambda2: starting averaging at time 3.2 div(Lambda2): starting averaging at time 3.2 Courant Number mean: 0.720607 max: 0.799872 Time = 3.2025 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 7.35683e-05, Final residual = 2.15586e-06, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.0610085, Final residual = 1.04745e-05, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.0491027, Final residual = 5.66325e-06, No Iterations 3 Pressure gradient source: uncorrected Ubar = 14.4122, pressure gradient = 0.246269 GAMG: Solving for p, Initial residual = 1, Final residual = 0.000369392, No Iterations 4 time step continuity errors : sum local = 1.34648e-11, global = -1.44398e-20, cumulative = -1.44398e-20 Pressure gradient source: uncorrected Ubar = 14.4122, pressure gradient = 0.25346 |
#15 |
Snigdha Ghosh
Rep Power: 6 ![]() |
I am using interFoam. However, I am using cray supercomputer to run my simulations. On spercomputer I have openfoam v 1712. On the other hand, I have openfoam 7 on my PC which uses Linux OS. After checking my code runs well on my PC I transferred my working directories to supercomputer. When I ran the simulations I got the same error: Reading "/home/metprocmodlgrp/144110018/two_sphere_3/system/controlDict" at line 1 First token could not be read or is not the keyword 'FoamFile' P.S. I replaced the version of all the file header from 7 to v1712. Still the same error is appearing. Can anyone help me on this? |
Unknown function type pressureTools | Dorian1504 | OpenFOAM Post-Processing | 23 | May 25, 2021 09:24 |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
[mesh manipulation] refineMesh Error | mohsen.boojari | OpenFOAM Meshing & Mesh Conversion | 3 | March 1, 2018 22:07 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
