Thermal Resistance in BuoyantBousinesqSimpleFoam |
August 14, 2019, 08:55 |
Owais Shabbir
Rep Power: 7 |
Dear all,
I want to apply a boundary condition on a wall so it duplicate the following behaviour from ANSYS: >Thermal resistance: The wall of solid.stl is covered by a plastic foil with a thickness of 0.13 mm and a thermal conductivity (k) of 0.19 W/(m K). So it can a thermal conductivity (k) of 0.19 W/(m K). This gives a thermal resistance between wall and air of 0.00068 m 2 K/W in a simulation Is there a way to introduce this? I have checked the externalHeatFluxWallTemperature but that seems to be applicable in MultiRegion simulations. Thanks |
August 14, 2019, 10:42 |
Rep Power: 20 |
{ type externalWallHeatFluxTemperature; // option 1 mode coefficient; // ambient temp. and htc Ta constant 300.0; h uniform 10.0; // option 2 mode power; Q 10; // [10W] // option 3 mode flux; q uniform 10.0; // [10W/m²] thicknessLayers (0.1 0.2 0.3 0.4); kappaLayers (1 2 3 4); value $internalField; } |
August 15, 2019, 02:45 |
cht solver with bousinessq model
Owais Shabbir
Rep Power: 7 |
Dear Bloerb,
Thanks a lot for this BC. I'm using OFv5. I have already developed a chtMultiRegionSimpleFoam model as well. But as you know the heat source is only possible to add through fvOptions. I wanted to use this BC but the boundary patch for my solid.stl is overridden by solid_to_fluid patches. Therefore, I couldn't use this BC for my solid in cht and had to move to buoyantBousinessqSimpleFoam. Secondly, you mention cht solver with boussinessq model? could you throw some more lights on it. Do I have to change the solver settings and introduce new equations? Because my knowledge with that is null. In my case I have two solids (one of them is generating heat) in the fluid region. Expectedly, I know the delta T_air is less than 20K. and what do you mean by "The cht solver can solve only 1 region". |
August 15, 2019, 03:08 |
Rep Power: 20 |
thermoType { type ...; mixture ...; transport ...; thermo ...; equationOfState Boussinesq; specie ...; energy ...; } The CHT solver is basically BuoyantBousinesqSimpleFoam / BuoyantSimpleFoam. The only difference is that you have to move all the settings you'd make in that solver into subfolders. You then have to specify all the regions in regionProperties. Do not add a solid region if you do not need it and it should behave (nearly) identical. Code:
regions ( fluid (fluidRegionA) solid () ); solid_to_fluid patches are created automatically if the mesh is split into different regions using splitMeshRegions. Inside the polyMesh/boundary files you'll find that those patches are of type mappedWall. Replace that by wall and they are uncoupled. You obviously can't use the coupling BC turbulentTemperatureCoupledBaffleMixed on them anymore, but you could use externalWallHeatFluxTemperature. Or simply use the mesh from your BuoyantBousinesqSimpleFoam case |
August 15, 2019, 04:59 |
equationofState Boussinesq
Owais Shabbir
Rep Power: 7 |
Hi Bloerb,
I have searched and this link states that there is the option of boussinesq model for of5. https://cfd.direct/openfoam/user-gui...35-2640007.1.5 I want to try this model on my old CHT where I have 2 solid regions in a fluid domain before I can implement single region. Now with this said, I just need to change the entry in thermophysicalProperties of air and introduce 'transportProperties' in addition in my CHT case setup. Or do I need to make any other changes? Thanks |
August 15, 2019, 05:25 |
Rep Power: 20 |
Yes, excactly. You don't need to create a transportProperties file, but OpenFOAM will ask you define the missing parameter inside thermophysicalProperties.
August 15, 2019, 09:44 |
Validity of Boussinesq Approx
Owais Shabbir
Rep Power: 7 |
Hi Bloerb,
I am slightly confused regarding the validity of this model in my case setup. I read at different places that this B. approx is valid if delta_T is 15K but this is even valid if my inlet_air is at 348K and the expected heat increases is 20K at maximum? T_inlet=348K T_outlet=368K (max limit) pressure drop is 30Pa but i have to run same setup with 200Pa and 300Pa as well. Secondly, in transportProperties, do I have to chose Tref = 348K or 296K ? or it doesn't matter?. Thanks |
Thermal Stress - Modelling of an interactive coupled Simulation | macRC | Structural Mechanics | 0 | January 10, 2019 05:14 |
Variable Thermal Contact Resistance | octavyo | CFX | 3 | March 13, 2011 11:11 |
modeling thermal resistance in Fluent? | gholamghar | FLUENT | 1 | August 28, 2010 12:07 |
Thermal contact resistance without meshing it? | rosco | FLUENT | 2 | June 30, 2003 17:50 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
