Pressure boundary conditions, simpleFoam, plate near a wall
Old   October 21, 2019, 11:37
Default Pressure boundary conditions, simpleFoam, plate near a wall
Ryan
RyArPa is on a distinguished road
Hi all,
I am trying to solve steady, laminar, shear flow about a plate near a wall. The aim is to understand how separation and flow reversal occur as viscosity changes and the gap between the plate and wall decreases.
I am using simpleFoam, however cannot work out which BCs to use. I have searched the internet and literature high and low and cannot get to a suitable answer.
- Here I am not sure that the zeroGradient condition holds because nu is non-zero/relatively large and with the plate inclined towards, and close to the wall, the usual arguments of du/dx = 0 etc do not follow.
As a result I feel as though the way forward is to have dp/dn = nu d2v/dn2 on the lower wall and plate boundaries. Is there a way of achieving this in OF and simpleFoam? or should I use a different solver?
The other BCs are:
- Plate: U = zeroGradient; p = ???
- Wall: U = U_w (positive or negaitve_; p = ???
- Inlet: U = U_w + y; p = zeroGradient
- Outlet: U = zeroGradient; p = 0
- Upper: U = U_W + y_max; p = zeroGradient
Any help or advice is appreciated!
RyArPa is offline   Reply With Quote
Old   October 22, 2019, 07:30
Carlo_P
Carlo_P is on a distinguished road
Hey,
I corrected your BCs:
-Plate: U = zeroGradient; p = zeroGradient
- Wall: U = U_w (positive or negaitve_; p = zeroGradient
but..I have a question: how you can calculate the separation using a laminar flow?
Carlo_P is offline   Reply With Quote
Old   October 22, 2019, 07:57
Ryan
Thanks Carlo_P for your time and response.
My supervisor and I are not convinced that the zeroGradient condition holds in this case though due to the presence of the plate and the viscousity of the fluid. I have read the other threads on here and I am not sure the justification there hold here for either the wall or the plate. Could you explain why the zeroGradient would be the correct choice?
As for separation, why would laminar flow be an issue? In theory it is admissible in a laminar boundary layer, and we do see the typical characteristics with flow reversal about the plate, eddies forming below the plate and in the wake, and adverse pressure gradients in the cases we've run.
Old   October 23, 2019, 04:08
Ryan
In addition, out of interest - is there a way to set a boundary condition of dp/dn = nu d^2v/dn^2 in OF?
Old   October 23, 2019, 04:19
Ruiyan Chen
cryabroad is on a distinguished road
I think it would be better if you put up a figure that shows the domain the boundaries. I'm kind of interested in this, is the plate parallel to the wall and you decrease the distance between them to see what are the effects?
zeroGradient for pressure is pretty straightforward, if you have a pressure gradient near a wall boundary, there will be flow penetrating it, which is physically not possible. You mentioned something about very large fluid viscosity, but that should have nothing to do with pressure. I see that you are using zeroGradient for velocity of the plate, is the plate moving? Anyway, a simple figure would help a lot here.
cryabroad is offline   Reply With Quote
Old   October 23, 2019, 04:51
Ryan
Thanks for your interest and advice cryabroad - that is helpful, and it is a fascinating problem when you get into it!
Here is a figure.
- The plate is inclined to the wall, with varying inclination for different scenarios.
- We are in a frame of reference fixed on the plate, so it is static but the wall is moving relative to the plate in either an upstream or downstream direction (giving a positive or negative wall velocity) such that the inlet velocity profile is: U = Uw + y, with the wall at y = 0, and the plate some varying distance from the wall.
The plate U BC was an error - it is no-slip. Sorry.
As for zeroGradient pressure, my understanding was that a pressure gradient near the wall would be equivalent to flow penetrating it, however, from the equations we keep landing at: dp/dn = nu d^2v/dn^2 as the correct condition on the wall... I can't quite resolve this.
Old   October 24, 2019, 04:41
Ruiyan Chen
Okay now I get the point. I think the problem may come from the reference frame you are working with. I guess you have to add certain terms in the equation to make the reference frame work, and that's probably why you end up with additional terms. Can you share the derivation of the dp/dn term you mentioned? I think this is where the confusion is. I still think the pressure boundary condition should be zeroGradient, because there should be no additional acceleration term (pressure gradient is basically acceleration) if things are moving at constant speeds in your original problem (before you change the reference frame).
Additionally, do check if OpenFOAM has built-in moving reference frame (MRF) modules. I think it does, at least I know Fluent has it. Such built-in modules should be designed in a way that the user doesn't need to worry about things related to MRF, in that case the pressure boundary condition should definitely be zeroGradient on the wall.
Old   October 24, 2019, 12:45
Ryan
[Duplicated post]
Last edited by RyArPa; October 25, 2019 at 04:20. Reason: Accidental duplication of posts - see below
Old   October 24, 2019, 14:08
Ryan
Thanks that its helpful advice - I will look into it!
As for the derivation of the BC for pressure (working for the wall, for ease, where the normal is in the y -axis), I am solving the continuity and momentum equations in 2D:
(1) u_x + v_y = 0
(2) uu_x + vu_y = -p_x + \nu (u_{xx}+u_{yy})
(3) uv_x + vv_y = -p_y + \nu (v_{xx}+v_{yy})
The velocity BCs on the wall are: u = u_w, which is constant for x (such that u_x = u_{xx}=0); and v = 0 which is constant in x (but not necessarily in y)
Hence, u_x = 0 such that by (1): v_y = 0
Plugging all of this into (3) we get: p_y = \nu v_{yy} \neq 0 (although v = 0 and v_y = 0, the overall profile of v is unknown, hence, for example, there could be quadratic contributions such that the above all holds - in fact such contributions are likely given the locality of the plate to the wall and the effect on the fluid flow as a result of its presence).
As a result this makes the BC: p_y = \nu v_{yy}.
This all leaves me with three questions that I am pondering/looking in to... (which I will continue to mull over!!!):
(1) does the above mean that the zeroGradient condition is inappropriate for pressure?
(2) if so, what alternatives/methods are there available in OF to resolve this?
(3) if it is appropriate, why? are there nuances in OF's implementation of the SIMPLE algorithm that I have not considered or perhaps the mathematics above incorrect?
Old   November 4, 2019, 01:43
Ruiyan Chen
Sorry for my late response, got caught up in some projects.
I went through your derivation, and I'm not sure if the second inequality in this expression holds, p_y = \nu v_{yy} \neq 0. We don't know what the gradient of wall normal velocity is before we solve the problem, why the inequality? The correct way of doing this is to assume p_y = 0 and go from there.
For boundary value problems, one can only specify one type of boundary condition for one variable at one boundary. In this case, v = 0 at the wall is sufficient for v, to state v_{yy} \neq 0 at the wall is an overconstraint I think. For example, just from the above expression, v can be a linear function with respect to the wall distance and satisfies the constraint of v = 0 at the wall. In such case, p_y = \nu v_{yy} = 0. Anyway, I think searching for MRF in OpenFOAM should be a good option for your case.
Old   November 20, 2019, 04:30
Ryan
Hi cryabroad, sorry for the delay (I have been away on leave).
One slight confusion, it's my fault for not being clearer - I am not imposing v_{yy} \neq 0, rather I probably should have said v_{yy} = C, where C is some constant that may or may not be 0. Hence, v_{yy} is calculated at the boundary, for which C is found rather than set. If anything, forcing C = 0 over-constrains the problem in my mind?
Old   November 23, 2019, 05:46
Ruiyan Chen
I think we both agree that the first equality holds, which is p_y = \nu v_{yy}. The problem is how do we go from here.
As I mentioned, for such a boundary value problem, to state anything associated with v_{yy} when we already establish the fact that v = 0 is not right, and it does over-constrain the problem. Even if you are assuming v_{yy} = some constant, that is not right in my mind.
However, in fluid mechanics pressure and velocity are coupled. When you specify a boundary condition for pressure/velocity, it implicitly constrains the velocity/pressure (in one form or the other) at the same boudary, which looks like you are over-constraining the problem. In other words, it is not that the v_{yy}=0 condition is forced by us, it is forced by continuity. Again, I do think that for an accelerating or decelerating system this is NOT the case, and more derivations have to be done to figure out the correct boundary conditions. But for the system you are considering (which is at constant speed), I think it should be just as simple as a normal zero pressure gradient condition.
Old   November 27, 2019, 06:06
Ryan
Thanks for your time on this - I think I understand what you are saying now and it is becoming clearer in my mind. I still have a reservation though.
You say:
To clarify: I am not looking to say that v_{yy} is definitely some constant and thus imposed that as a BC alongside a pressure BC and another velocity BC, since this would over constrain the problem.
Rather, v_{yy} could be constant, or zero, or something else, we don't know. Hence I am looking for a pressure BC such that p_{y}  = \nu v_{yy} on the boundary.
I think is mathematically valid since with a zeroGradient BC we have p_{y}  = 0 = \nu v_{yy} and are imposing a value on v through the pressure coupling. Which is what I would like to do here, but for a potentially non-zero value.
simplefoam pressure bc
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
Wrong multiphase flow at rotating interface Sanyo CFX 14 February 7, 2017 17:19
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
interFoam (HELYX-OS) pressure boundary conditions SFr OpenFOAM Running, Solving & CFD 8 June 23, 2016 16:36
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
