FOAM FATAL ERROR: Maximum number of iterations exceeded: 100
Old   October 10, 2019, 11:15
Default FOAM FATAL ERROR: Maximum number of iterations exceeded: 100
Antonio
antoniomollo is on a distinguished road
I am a new user of OpenFoam. I have this error, I tried different ways to avoid this but the result is the same. Can anyone help me?
I understood that there is a problem with energy equation...but I don't know.
Thanks.
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 6
\\/ M anipulation |
Build : 6-e29811f5dff8
Exec : rhoPimpleFoam
Date : Oct 10 2019
Time : 17:05:43
Host : "antoniom91-HP-Pavilion-x360-Convertible"
PID : 5472
I/O : uncollated
Case : /home/antoniom91/OpenFOAM/antoniom91-6/run/VFP_simulation2_rho_simple
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: No convergence criteria found
PIMPLE: Corrector convergence criteria found
"(U|k|epsilon)": tolerance 0.0001, relTol 0
Calclations will do 50 corrections if the convergence criteria are not met
Reading thermophysical properties
Selecting thermodynamics package
type hePsiThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState perfectGas;
specie specie;
energy sensibleEnthalpy;
Reading field U
pressureControl
pMax 1500000
pMin 100000
Creating turbulence model
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
RAS
RASModel kEpsilon;
turbulence on;
printCoeffs on;
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 0;
sigmak 1;
sigmaEps 1.3;
Creating field dpdt
Creating field kinetic energy K
No MRF models present
No finite volume options present
Courant Number mean: 0.0014163604 max: 5.065195
Starting time loop
Courant Number mean: 0.0013968052 max: 4.9952613
deltaT = 9.8619329e-06
Time = 9.86193e-06
PIMPLE: Iteration 1
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.01541721, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.023338802, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.021696637, No Iterations 1
smoothSolver: Solving for h, Initial residual = 1, Final residual = 0.002021401, No Iterations 3
GAMG: Solving for p, Initial residual = 1, Final residual = 0.0082120498, No Iterations 2
GAMG: Solving for p, Initial residual = 0.031349804, Final residual = 0.001157596, No Iterations 1
time step continuity errors : sum local = 0.00086029742, global = -6.1886942e-05, cumulative = -6.1886942e-05
pressureControl: p max 2048360.3
GAMG: Solving for p, Initial residual = 0.35939903, Final residual = 0.0023679751, No Iterations 2
GAMG: Solving for p, Initial residual = 0.019107717, Final residual = 0.0011200636, No Iterations 1
time step continuity errors : sum local = 0.0019050911, global = 0.0014242547, cumulative = 0.0013623678
smoothSolver: Solving for epsilon, Initial residual = 0.7155894, Final residual = 0.031617312, No Iterations 1
bounding epsilon, min: -32.865838 max: 210676.04 average: 329.31726
smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.050063332, No Iterations 1
PIMPLE: Iteration 2
smoothSolver: Solving for Ux, Initial residual = 0.1885659, Final residual = 0.00552603, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.43538988, Final residual = 0.0041218538, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.43413677, Final residual = 0.0042201254, No Iterations 1
smoothSolver: Solving for h, Initial residual = 0.74736897, Final residual = 0.0061303172, No Iterations 4
GAMG: Solving for p, Initial residual = 0.75047041, Final residual = 0.0038408842, No Iterations 1
GAMG: Solving for p, Initial residual = 0.001399869, Final residual = 0.001399869, No Iterations 0
time step continuity errors : sum local = 0.0023359741, global = -0.0012983479, cumulative = 6.4019828e-05
pressureControl: p max 37145843
pressureControl: p min -1102504.2
GAMG: Solving for p, Initial residual = 0.54157365, Final residual = 0.0045490989, No Iterations 1
GAMG: Solving for p, Initial residual = 0.0031541605, Final residual = 0.0031541605, No Iterations 0
time step continuity errors : sum local = 0.0055287247, global = -0.0020528002, cumulative = -0.0019887804
pressureControl: p max 48090802
pressureControl: p min -34043479
smoothSolver: Solving for epsilon, Initial residual = 0.10537911, Final residual = 0.0010463339, No Iterations 1
bounding epsilon, min: -118502.74 max: 1.1528773e+09 average: 32663.937
smoothSolver: Solving for k, Initial residual = 0.85080698, Final residual = 0.018905995, No Iterations 2
PIMPLE: Iteration 3
smoothSolver: Solving for Ux, Initial residual = 0.14157198, Final residual = 0.0061435985, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.24628262, Final residual = 0.013605369, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.24371158, Final residual = 0.013440339, No Iterations 1
smoothSolver: Solving for h, Initial residual = 0.16678901, Final residual = 0.0014007156, No Iterations 3
GAMG: Solving for p, Initial residual = 0.43836041, Final residual = 0.0015686454, No Iterations 1
GAMG: Solving for p, Initial residual = 0.00058446854, Final residual = 0.00058446854, No Iterations 0
time step continuity errors : sum local = 0.00089785328, global = -0.00065931356, cumulative = -0.0026480939
pressureControl: p max 45989243
pressureControl: p min -17902714
GAMG: Solving for p, Initial residual = 0.38769917, Final residual = 0.0017128437, No Iterations 1
GAMG: Solving for p, Initial residual = 0.00071476724, Final residual = 0.00071476724, No Iterations 0
time step continuity errors : sum local = 0.0011236984, global = -0.00081905666, cumulative = -0.0034671506
pressureControl: p max 87261603
pressureControl: p min -31612707
smoothSolver: Solving for epsilon, Initial residual = 0.10539707, Final residual = 0.0041859928, No Iterations 1
bounding epsilon, min: -6.4329239e+08 max: 3.2489285e+11 average: 28509511
smoothSolver: Solving for k, Initial residual = 0.24679149, Final residual = 0.0048989557, No Iterations 2
PIMPLE: Iteration 4
smoothSolver: Solving for Ux, Initial residual = 0.99892642, Final residual = 0.020548135, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.99985405, Final residual = 0.088095772, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.9998084, Final residual = 0.015464463, No Iterations 2
smoothSolver: Solving for h, Initial residual = 1, Final residual = 0.0032430201, No Iterations 4
--> FOAM FATAL ERROR:
From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam:erfectGas<Foam::specie> >; Type = Foam::sensibleEnthalpy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam:er fectGas<Foam::specie> >, Foam::sensibleEnthalpy>]
in file /home/ubuntu/OpenFOAM/OpenFOAM-6/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 73.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam::hePsiThermo<Foam:siThermo, Foam:ureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam:erfectGas<Foa m::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ??:?
#3 Foam::hePsiThermo<Foam:siThermo, Foam:ureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam:erfectGas<Foa m::specie> >, Foam::sensibleEnthalpy> > > >::correct() at ??:?
#4 ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam"
#5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#6 ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam"
antoniomollo is offline   Reply With Quote
Old   October 10, 2019, 14:44
clapointe is on a distinguished road
You have massive min/max pressures (and negative pressure!) from the beginning. Suggests boundary/initial condition problem.
Caelan
clapointe is offline   Reply With Quote
Old   October 10, 2019, 15:08
Antonio
Caelan
I have corrected the boundary. But the error is the same.
\\/ M anipulation |
Date : Oct 10 2019
Time : 21:05:53
PID : 5296
I/O : uncollated
nProcs : 1
Create time
type hePsiThermo;
transport const;
thermo hConst;
specie specie;
Reading field U
RAS
RASModel kEpsilon;
turbulence on;
printCoeffs on;
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 0;
sigmak 1;
sigmaEps 1.3;
Creating field dpdt
Starting time loop
Time = 9.86193e-06
PIMPLE: Iteration 1
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0067606, No Iterations 1
GAMG: Solving for p, Initial residual = 1, Final residual = 0.0087385529, No Iterations 3
GAMG: Solving for p, Initial residual = 0.04134101, Final residual = 0.0024747188, No Iterations 1
time step continuity errors : sum local = 3.8173259e-05, global = -3.2038111e-06, cumulative = -3.2038111e-06
GAMG: Solving for p, Initial residual = 0.43076641, Final residual = 0.004968437, No Iterations 3
GAMG: Solving for p, Initial residual = 0.034180016, Final residual = 0.0020686053, No Iterations 1
time step continuity errors : sum local = 4.92591e-05, global = -2.765535e-06, cumulative = -5.9693461e-06
smoothSolver: Solving for epsilon, Initial residual = 0.02463015, Final residual = 0.00069668943, No Iterations 1
bounding epsilon, min: -32.879214 max: 25055.446 average: 267.28537
smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.043250315, No Iterations 1
PIMPLE: Iteration 2
smoothSolver: Solving for Ux, Initial residual = 0.72034491, Final residual = 7.5697148e-05, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.41292388, Final residual = 4.2416415e-05, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.40803199, Final residual = 4.3650929e-05, No Iterations 1
smoothSolver: Solving for h, Initial residual = 0.1605451, Final residual = 0.00087375001, No Iterations 3
GAMG: Solving for p, Initial residual = 0.3454394, Final residual = 0.0042882372, No Iterations 2
GAMG: Solving for p, Initial residual = 0.003520348, Final residual = 0.003520348, No Iterations 0
time step continuity errors : sum local = 9.685274e-05, global = 1.2610556e-05, cumulative = 6.64121e-06
GAMG: Solving for p, Initial residual = 0.28431697, Final residual = 0.0037378878, No Iterations 2
GAMG: Solving for p, Initial residual = 0.0029046327, Final residual = 0.0029046327, No Iterations 0
time step continuity errors : sum local = 0.0001278336, global = 1.9418362e-05, cumulative = 2.6059572e-05
smoothSolver: Solving for epsilon, Initial residual = 0.02724506, Final residual = 4.5704602e-06, No Iterations 1
bounding epsilon, min: -64190.597 max: 6224817.7 average: 1134.893
smoothSolver: Solving for k, Initial residual = 0.2591801, Final residual = 0.00015350397, No Iterations 1
PIMPLE: Iteration 3
smoothSolver: Solving for Ux, Initial residual = 0.99999963, Final residual = 0.032678231, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.99997201, Final residual = 0.022285855, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.99999693, Final residual = 0.058668532, No Iterations 1
smoothSolver: Solving for h, Initial residual = 1, Final residual = 0.0032136039, No Iterations 3
FOAM aborting
Old   October 10, 2019, 15:10
Antonio
These are the boundary:
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object alphat;
dimensions [1 -1 -1 0 0 0 0];
internalField uniform 0;
boundaryField
iniettore_1
type calculated;
value uniform 0;
iniettore_3
type calculated;
value uniform 0;
lato_N2
type compressible::alphatWallFunction;
Prt 0.85;
value uniform 0;
outlet
type calculated;
value uniform 0;
iniettore_2
type calculated;
value uniform 0;
iniettore_4
type calculated;
value uniform 0;
braccio_iniettori
Prt 0.85;
value uniform 0;
lato_ugello
Prt 0.85;
value uniform 0;
ugello
Prt 0.85;
value uniform 0;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
location "0";
object epsilon;
dimensions [0 2 -3 0 0 0 0];
internalField uniform 2;
boundaryField
iniettore_1
type turbulentMixingLengthDissipationRateInlet;
mixingLength 0.02;
value uniform 2;
iniettore_3
mixingLength 0.02;
value uniform 2;
lato_N2
type epsilonWallFunction;
value uniform 2;
outlet
type zeroGradient;
iniettore_2
mixingLength 0.02;
value uniform 2;
iniettore_4
mixingLength 0.02;
value uniform 2;
braccio_iniettori
value uniform 2;
lato_ugello
value uniform 2;
ugello
value uniform 2;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
location "0";
object k;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0.375;
boundaryField
iniettore_1
type turbulentIntensityKineticEnergyInlet;
intensity 0.05;
value uniform 0.375;
iniettore_3
intensity 0.05;
lato_N2
type kqRWallFunction;
outlet
type zeroGradient;
iniettore_2
intensity 0.05;
iniettore_4
intensity 0.05;
braccio_iniettori
lato_ugello
ugello
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
location "0";
object nut;
dimensions [0 2 -1 0 0 0 0];
boundaryField
iniettore_1
type calculated;
value uniform 0;
iniettore_3
type calculated;
value uniform 0;
lato_N2
type nutkWallFunction;
value uniform 0;
outlet
type calculated;
value uniform 0;
iniettore_2
type calculated;
value uniform 0;
iniettore_4
type calculated;
value uniform 0;
braccio_iniettori
value uniform 0;
lato_ugello
value uniform 0;
ugello
value uniform 0;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
location "0";
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 101325;
boundaryField
iniettore_1
type zeroGradient;
iniettore_3
type zeroGradient;
lato_N2
type zeroGradient;
outlet
type waveTransmissive;
rho rho;
gamma 1.4;
fieldInf 101325;
lInf 10;
value uniform 101325;
iniettore_2
type zeroGradient;
iniettore_4
type zeroGradient;
braccio_iniettori
type zeroGradient;
lato_ugello
type zeroGradient;
ugello
type zeroGradient;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
location "0";
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 300;
boundaryField
iniettore_1
type zeroGradient;
iniettore_3
type zeroGradient;
lato_N2
type fixedValue;
value uniform 820;
outlet
type zeroGradient;
iniettore_2
type zeroGradient;
iniettore_4
type zeroGradient;
braccio_iniettori
type zeroGradient;
lato_ugello
type fixedValue;
value uniform 820;
ugello
type zeroGradient;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
iniettore_1
type fixedValue;
value uniform (0 -300 0);
iniettore_3
type fixedValue;
value uniform (0 0 300);
lato_N2
type noSlip;
outlet
type zeroGradient;
iniettore_2
type fixedValue;
value uniform (0 300 0);
iniettore_4
type fixedValue;
value uniform (0 0 -300);
braccio_iniettori
type noSlip;
lato_ugello
type noSlip;
ugello
type noSlip;
Old   October 11, 2019, 00:22
Just a quick glance, but it looks like you tried to specify velocity at 4 patches, which I presume are inlets/outlets, and pressure at none of them. This could be why the simulation is blowing up. I don't know which solver you're using, but I would take a look at the tutorials for examples of how to set pressure/velocity at inlets/outlets.
Caelan
Old   March 2, 2023, 06:13
Héloïse Magliano
HeloïseM is on a distinguished road
Hello, I have a similar problem i think but all seems okay regarding boundary conditions and setFieldsDict. I am running a specific mesh with the ddtFoam solver to modelize deflagration to detonation combustion in a rotational detonation engine.
The checkMesh indicates that everything is okay with it.
I have this error:
Acoustic Courant Number mean: 1.12966e-05 max: 0.317766
deltaT = 4.29456e-11
Time = 0.000055444344, time step = 680
Quenching 0.170678 % of the turbulent reaction
Calculating Riemann fluxes, second order = true
DICPCG: Solving for Ux, Initial residual = 3.43464e-05, Final residual = 2.94524e-15, No Iterations 1
DICPCG: Solving for Uy, Initial residual = 0.00309516, Final residual = 1.94156e-15, No Iterations 1
DICPCG: Solving for Uz, Initial residual = 0.00869599, Final residual = 5.231e-17, No Iterations 1
DICPCG: Solving for fH, Initial residual = 1.51402e-07, Final residual = 1.51402e-07, No Iterations 0
diagonal: Solving for tauHI, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for tauLO, Initial residual = 0, Final residual = 0, No Iterations 0
DICPCG: Solving for c, Initial residual = 6.34503e-06, Final residual = 1.37472e-16, No Iterations 1
Combustion progress = 0.784048%
diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for rhoEu, Initial residual = 0, Final residual = 0, No Iterations 0
[8]
[8]
[8] --> FOAM FATAL ERROR:
[8] Maximum number of iterations exceeded
Test = 10280.7 K,
eu_ = 1.19965e+07 J/kg, e(Test,fH) = 1.18617e+07 J/kg
[8]
[8] From function eUnburnedThermo::correct(const volScalarField& fH)
[8] in file eUnburnedThermo/eUnburnedThermo.C at line 413.
[8]
FOAM parallel run aborting
[8]
[8] #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
[8] #1 Foam::error::abort() at ??:?
[8] #2 Foam::eUnburnedThermo::correct() at ??:?
[8] #3
[8] at ??:?
[8] #4 __libc_start_main in "/lib64/libc.so.6"
[8] #5
[8] at ??:?
MPI_ABORT was invoked on rank 8 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
Could someone try to help me please ?
HeloïseM is offline   Reply With Quote
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 09:10
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 14:05
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
formatted point data- icem HSK CFX 12 August 11, 2011 21:25
