Inconsistent behaviour of function object "scale"
Old   October 10, 2019, 09:12
Default Inconsistent behaviour of function object "scale"
Sita Drost
sita is on a distinguished road
Hi all,
I've been using velocity ramping to start my OF7 interFoam simulations for a while now, without too much trouble so far. However, in my most recent simulation, OpenFOAM suddenly no longer recognises the keyword "duration" in the "scale" entry in 0/U and fvOptions:
[0] --> FOAM FATAL IO ERROR:
[0] Illegal dictionary entry or environment variable name "duration"
Valid dictionary entries are
2
type
start
The strangest thing is that, when I go back to one of my previous cases and re-run it, they all still run without complaint. I'm fairly sure that there aren't any differences in how I defined the velocity ramp in my current case (in fact I foamClone'd it from one of the previous cases). The only difference I can think of is that, in this problematic case, I'm using a mesh created by SnappyHexMesh, while in all the other cases I used meshes imported from an external mesher. But I can't see how that would influence OF's behaviour regarding scale functionObjects.
Can anyone help me with this?
Many thanks,
Sita
P.S. For sake of completeness, I've also included the contents of my 0/U and fvOptions files below
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      binary;
    class       volVectorField;
    location    "0";
    object      U;
#include        "../constant/refValues";
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    atmosphere
        type            pressureInletOutletVelocity;
        value           uniform (0 0 0);
    inlet
        type            uniformFixedValue;
        value            $internalField;
        uniformValue
            value        (#neg $Uref 0 0);
            type         scale;
            scale
                type    quarterSineRamp;
                start    0;
                duration $duration;
    outlet
        type            outletPhaseMeanVelocity;
        alpha           alpha.water;
        UnMean
            value        $Uref;
            type        scale;
            scale
                start        0;
                duration    $duration;
    bottom
        type            symmetryPlane;
    side
        type            symmetryPlane;
    midPlane
        type            symmetryPlane;
    hull
        type            movingWallVelocity;
    \\  /    A nd           | Version:  dev
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      fvOptions;
#include    "refValues";
limitU
    type            limitVelocity;
    active            yes;
    selectionMode    all;
    max                50;
    duration         1000000.0;
velocityRamping
    type        accelerationSource;
    active      on;
    selectionMode all;
    U           U;
     velocity
        type    scale;
        scale
            start       0;
            duration    $duration;
sita is offline   Reply With Quote
Old   October 14, 2019, 08:36
Sita Drost
Update: by replacing the "duration" keyword in fvOptions in one of my old cases (one that did run) by "banana", I noticed that in the case that's throwing errors, OpenFOAM seems to be looking for "scale" in a different location.
In the working cases OpenFOAM looks in lnInclude/dictionaryTemplates.C, while in my problematic case it looks in db/dictionary/primitiveEntry/primitiveEntry.C
Does anyone have any idea what's going wrong here?
Many thanks,
Sita
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 11:04
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 10:05
How to create a function object in OpenFoam that runs properly ? mkhm OpenFOAM Programming & Development 1 October 20, 2018 16:16
[snappyHexMesh] Problem with parallel run of snappyHexMesh Lorenzo92 OpenFOAM Meshing & Mesh Conversion 5 April 15, 2016 04:12
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
