multiphaseEulerFoam - sensitive to many parameters (unphysical results) |
October 21, 2019, 22:12 |
Alejandro
Rep Power: 12 |
I am running multiphaseEulerFoam for a 2D channel with a given inlet water velocity and inlet air from porous walls.
I am obtaining totally different results if I use constant deltaT or variable deltaT (Co < 0.2). Also, I obtained different results by changing nCorrectors from 1 to 2 or 3, or by modifying nOuterCorrectors (a different result for each setting...) Finally, modifying residualPhaseFraction and residualSlip change a lot the final steady-state solution. Does anyone know what is happening? Am I doing something wrong? Does anyone know a validation case for multiphaseEulerFoam? Because all tutorials I saw and even some research papers just show colors ("phases") mixing together... |
Problem: Very long "write" time (~2h-3h) for results and transient results | Shawn_A | CFX | 16 | April 12, 2016 20:49 |
Transient Run - Output "Time" in partial results? | evcelica | CFX | 2 | May 16, 2012 21:36 |
results on wall force (expert parameters) | syafiq | CFX | 1 | October 5, 2011 05:35 |
Different Results from Fluent 5.5 and Fluent 6.0 | Rajeev Kumar Singh | FLUENT | 6 | December 19, 2010 11:33 |
Comparison between turbulent parameters with analytical or experimental results | fareedmangi | FLUENT | 0 | June 2, 2009 10:41 |
