Problem while trying to solve
Old   November 26, 2019, 14:26
Default Problem while trying to solve
Florian
NightRippers is on a distinguished road
Hello All !
First, i am a beginner in Ubuntu and OpenFoam :O
I use gmsh to create a mesh, i convert it to Foam via gmshToFoam, i checked the mesh with checkMesh. To calculate, i use icoFoam, but when trying to solve a case that my teacher did in class, i have this message :
 icoFoam
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
Build  : 6-47517f2ebb1b
Exec   : icoFoam
Date   : Nov 26 2019
Time   : 20:01:04
Host   : "florian-GS65-Stealth-9SD"
PID    : 3813
I/O    : uncollated
Case   : /media/florian/Data/GMSHFILES/TEST_AFC_22_NOV_2019
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0.2
Reading transportProperties
Reading field p
--> FOAM FATAL ERROR:
cannot find file "/media/florian/Data/GMSHFILES/TEST_AFC_22_NOV_2019/0.2/p"
    From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const
    in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 519.
FOAM exiting
I look on internet but i didn't found any information about that. If someone could help me please
Have a good day
Florian
NightRippers is offline   Reply With Quote
Can OpenFoam solve this problem? salazardetroya OpenFOAM Running, Solving & CFD 1 July 29, 2015 22:34
Which multiphase flow to solve this problem? mariam.sara Fluent Multiphase 3 May 4, 2014 11:04
how to solve a problem involving both laminar and turbulent flow seefd FLUENT 1 June 3, 2011 03:20
Could CFX solve hydraulic jump problem? Andy Chen CFX 0 August 18, 2009 10:13
Can CFX solve problem with structured mesh? Peted CFX 2 May 31, 2004 23:45
