OpenFOAM 6, chtMultiRegionFoam residualcontrol for steady state not working
Like Tree4Likes
  • 2 Post By Robin.Kamenicky
  • 1 Post By qtruong
  • 1 Post By Robin.Kamenicky
Old   August 28, 2018, 09:45
Default OpenFOAM 6, chtMultiRegionFoam residualcontrol for steady state not working
qtruong is on a distinguished road
Since chtMultiRegionSimpleFoam was removed in OpenFOAM 6, I tried running a steady state case with chtMultiRegionFoam, with a residualcontrol (shown below). But it does not stop when converged. Has anyone tested if residualcontrol works in the new chtMultiRegionFoam?
PIMPLE
     residualcontrol
          U     1e-4;
qtruong is offline   Reply With Quote
Old   September 2, 2018, 06:46
Robin Kamenicky
Robin.Kamenicky is on a distinguished road
Hi qtruong,
could you try
residualControl
instead of
residualcontrol
Kind regards,
Robin
Robin.Kamenicky is offline   Reply With Quote
Old   September 3, 2018, 10:48
Originally Posted by Robin.Kamenicky View Post
Hi qtruong,
could you try
residualControl
instead of
residualcontrol
Kind regards,
Robin
thank you for the response.
Sorry, it was my typo while writing the post. It was actually "residualControl" in the code, and it's confirmed by the log file:
PIMPLE: Region gas
PIMPLE: Convergence criteria found
             U:    tolerance  0.0001
Otherwise, with lower "c", there would be "no convergence criteria found".
Nonetheless, the convergence is reached, but chtMultiRegionFoam keeps running until my endTime.
Old   September 3, 2018, 13:04
Robin Kamenicky
Hi qtruong,
the chtMultiRegionFoam should run till the endTime. It is transient solver not steady-state as chtMultiRegionSimpleFoam.
The residualControl allows to exit PIMPLE outer loops when the residual criteria are fulfilled. Then it continues with next time step.
Kind regards,
Robin
Old   September 4, 2018, 11:47
Hi qtruong,
Kind regards,
Robin
Is there then a way to solve steady state conjugate heat transfer in OpenFoam 6 ?
ordinary likes this.
Old   September 4, 2018, 12:12
Robin Kamenicky
Hi qtruong,
There is no solver for steady state conjugated heat transfer in OpenFoam6. However, if your problem is steady state problem, the transient solver will converge to steady state.
Eventually you can try to use local time stepping (localEuler time derivative approximation).
Another possibility is to use OpenFoam5 and chtMultiRegionSimpleFoam. If I understand right, the difference between OpenFoam5 and OpenFoam6 is only in usability for conjugated heat transfer solvers.
Hope it helps,
Robin
Old   March 2, 2019, 09:37
julien
julieng is on a distinguished road
I try to result a CHT steady state case with openfoam 6 and chtMultiRegionFoam. I am not able to solve it, it crashes after few time steps.
chtMultiRegionSimpleFoam done the job with Openfoam 5, I obtained good accuracy with analytical solutions.
I read your post Robin.Kamenicky, you wrote :
What is the reason to have give up the steady state solver in openfoam 6 ?
Best regards
julieng is offline   Reply With Quote
Old   March 2, 2019, 10:53
Robin Kamenicky
Hi julieng,
Actually, I have been mistaken. The official documentation of OF6 for chtMultiRegionFoam tells:
Solver for steady or transient fluid flow and solid heat conduction, with
     conjugate heat transfer between regions, buoyancy effects, turbulence,
     reactions and radiation modelling.
What was the error?
Kind regrads,
Robin
Old   March 2, 2019, 11:00
Robin Kamenicky
Hi julieng,
according to tutorials. You can setup scheme for time derivative to
steadyState
Kind Regards,
Robin
Old   March 4, 2019, 07:15
julien
Hello Robin,
Yes it works for stationary cases, I have test it. I have same results than openfoam v5.
I try the new functionnality
"wallHeatTransferCoeff"
I read on the Openfoam 6 release:
Data Processing: function objects for individual regions in a multi-region simulation [ commit a5a034 ]; wallHeatTransferCoeff function object to calculate the wall heat transfer coefficient [ commit 99841e ]; in wallHeatFlux, improved efficiency of heat flux calculation [ commit 6584fa ] and corrected contribution of radiative heat flux [ commit 396259 ].
But I see that it works only for incompressible fluids… cht is for compressible fluids. Maybe someone knows how to modify the file.
I see the post of bloerb
https://www.cfd-online.com/Forums/op...ing-print.html
But I Don't know how to do. I am a total beginner in function object.
Best regards
Old   December 18, 2019, 02:24
hokhay is on a distinguished road
Originally Posted by julieng View Post
Hello Robin,
Best regards
Do you need to change the anything in fvSolution and controlDict too? Such as relaxationFactors or Courant number.
Thank you
hokhay is offline   Reply With Quote
chtmultiregionfoam, heat transfer
Current state of conjugate heat transfer in OpenFOAM Dreoasteh OpenFOAM 2 April 4, 2023 13:47
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 06:15
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
error message cuteapathy CFX 14 March 20, 2012 06:45
