pimplefoam crashing while validating FSI2 of Turek-Hron FSI benchmark
Old   January 5, 2020, 06:07
Default pimplefoam crashing while validating FSI2 of Turek-Hron FSI benchmark
Nithin Adidela
nithinadidela is on a distinguished road
Hello foamers,
I am trying to validate TurekHron FSI benchmark with my FSI model.
I have used Openfoam v7 to solve the Fluid part and CalculiX to solve the solid part and coupled them both with precice.
FSI1 in which Reynold's number is 20 runs perfectly and gives accurate results.
While FSI2 in which Reynold's number is 100 sets up perfectly but crashes after a while. I am sure CalculiX or precice isn't the issue.
I cannot figure out what the problem is.
I am attaching the successfully ran steady case here and partially ran Unsteady case here
The log files for the fluid are in the directory itself.
I have attached an instructions text in case anyone is not informed enough to use precice environment.
Any help will be very much appreciated.
Thanking you in advance,
Nithin
nithinadidela is offline   Reply With Quote
calculix, fsi, openfoam, pimplefoam, precice
The Turek and Hron FSI Benchmark problem Satheesh kumar N SU2 1 August 12, 2018 10:10
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 12:13
