Running Allrun script as a superuser
Old   February 11, 2020, 10:37
Default Running Allrun script as a superuser
Alejandro Valeije
alexvaleije is on a distinguished road
Hello foamers,
I am currently developing a small GUI with Java to run openFOAM cases with it.
This GUI is meant to internally open a new terminal and execute the designated script.
The 5 first lines of my script are the following:
#!/bin/sh
cd ${0%/*} || exit 1 # Run from this directory
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
As you can see, these are the first lines in every Allrun script from every openFoam case.
The problem comes when running this script with the GUI. I think that it tries to execute it as a superuser and it tries to execute the following:
sudo ./RunCase
And the result is:
./RunCase: 5: .: Can't open /bin/tools/RunFunctions
So the question is: is there any way of running these type of scripts as a superuser? I don't think I'm able to change the routine that the GUI does when opening a terminal.
Thanks in advance
alexvaleije is offline   Reply With Quote
Old   February 11, 2020, 13:04
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
did you source OpenFOAM etc/bashrc somewhere prior to Allrun?
HPE is offline   Reply With Quote
Old   February 12, 2020, 04:12
Alejandro Valeije
In my /home/user/.bashrc the last line is:
source /opt/openfoam6/etc/bashrc
Since it seems that executing the script as a suepruser is not reading that line, I have tried to write the same line also in the script, before the RunFunctions line, but then, the error message is that the command source is not found.
I have also tried to write sudo source /opt/openfoam6/etc/bashrc alone in a terminal and the error reamins the same: command not found, so I guess the error goes in that direction, but I don't know how to fix it
Old   February 12, 2020, 09:41
courant_numero_uno is on a distinguished road
See the information here: https://askubuntu.com/questions/5045...nning-a-script
There is something going on with source being a bash command.
Try using this as the first line:
#!/bin/bash
courant_numero_uno is offline   Reply With Quote
Running OpenFOAM case through shell script (bash) ilaj OpenFOAM Programming & Development 2 January 28, 2020 13:14
Problem running Allrun ivanfb95 OpenFOAM 0 March 6, 2017 04:36
How can i activate the Allrun script? spk OpenFOAM 2 October 2, 2011 17:28
Empty Allrun script mwild OpenFOAM Bugs 4 August 25, 2009 02:43
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
