October 10, 2022, 05:14 |
CHTMultiRegionFoam
Nico
Rep Power: 6 |
Hey, i have a quite generall question regarding the chtMultiRegionFoam solver.
Considering that the chtMultiRegionSimpleFoam solver only exist in older versions, i have worked with a configuration of the solver that uses steady state for ddt schemes. However the shell and tube heat exchanger example uses PIMPLE options in fvoptions as well as the steady state ddt schemes. Does this even match, considering that i always assumed the PIMPLE solver as a solver for transient simulations. Does this mean the simulation is done quasi steady state? Considering that the Courant Number affected the results as well as execution time it might makes sense. However i spent now enough time searching that i consufed myself and would like to discuss with you guys, so that i hopefully one day end up with a true steady state chtMultiRegionFoam simulation. |
October 10, 2022, 06:16 |
Nico
Rep Power: 6 |
Hey!
If i start a simulation the log adds these lines: Code:
PIMPLE: Operating solver in steady-state mode with 1 outer corrector PIMPLE: Operating solver in SIMPLE mode Is this what you are referring to? I am just a bit confused to wether i am running a true steady sate simulation or if i have to change the PIMPLE entries in my fvSolution files to SIMPLE entries. |
October 10, 2022, 06:32 |
My reasoning might be too simplistic to be a genuine help to you.
I, however, was imaging running a simpleFOAM tutorial (e.g. Pitz-Daily) using pimpleFOAM and checking in which circumstances the same (or similar) residual convergence history is obtained. |
October 10, 2022, 06:42 |
Nico
Rep Power: 6 |
this is indeed quite a good idea, i will try this |
March 6, 2024, 03:34 |
Elias
I also encountered this situation when I set up a hydrogen combustion calculation example. Have you solved this problem?
Weird (unphysical) temperature rise with chtMultiRegionFoam | Phil910 | OpenFOAM Running, Solving & CFD | 3 | November 9, 2022 09:25 |
Help with PIMPLE algorithm in chtMultiregionFoam | Chris T | OpenFOAM Running, Solving & CFD | 0 | August 30, 2022 08:49 |
Error in thermophysical properties (chtMultiRegionFoam) | mukut | OpenFOAM Pre-Processing | 28 | November 23, 2021 06:34 |
chtMultiRegionFoam solver stops without any error | amol_patel | OpenFOAM Running, Solving & CFD | 2 | October 20, 2021 01:29 |
What does this error when use solver chtMultiRegionFoam mean | sajad6 | OpenFOAM Running, Solving & CFD | 7 | October 6, 2014 07:38 |
