February 29, 2020, 08:38 |
writeInterval not working
Carlos
Rep Power: 6 |
I'm new to OpenFOAM and I'm trying to run a microfluidics simulation. I have an issue inside controlDict file. startTime is 0 s, endTime is 0.2 s and I want to write a folder every 0.0016 s (a total of 125 folders). That is, writeInterval = 0.0016. The problem is that OF writes data every time step (deltaT = 0.000005 s), no matter what the value of writeInterval is. The controlDict file is the following: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application interFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 0.2; deltaT 0.000005; writeControl clockTime; writeInterval 0.0016; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep no; maxCo 2; maxAlphaCo 1; // ************************************************************************* // What is the problem? Thank you in advance, Carlos. |
March 1, 2020, 16:21 |
Akash Patel
Rep Power: 7 |
Try this, Code:
writeControl adjustableRunTime; writeInterval 0.0016;
We are developing an open-source software for constructing reduced order models for your CFD simulations in OpenFOAM that runs several magnitude faster. Visit the link below to learn more. AccelerateCFD - OpenFOAM based reduced order model solver for CFD using Proper Orthogonal Decomposition. |
March 1, 2020, 16:34 |
Carlos
Rep Power: 6 |
March 2, 2020, 03:55 |
Yann
Rep Power: 26 |
In addition, for the readers who might bump into this thread, I suggest reading the user guide here : https://cfd.direct/openfoam/user-guide/v6-controldict/
4.3.2 Data writing writeControl Controls the timing of write output to file.
Cheers, Yann |
controldict, writecontrol, writeinterval |
findCell() in parallel: not working if location is outside the domain | TobiWol | OpenFOAM | 0 | January 10, 2018 14:33 |
Processor 0 not working | vishwesh | OpenFOAM Running, Solving & CFD | 0 | November 17, 2017 03:35 |
IcoFoam with variable time step not writing every writeInterval | wildfire230 | OpenFOAM Running, Solving & CFD | 1 | July 31, 2013 17:49 |
DPM parallel is not working but serial is working | johnwinter | FLUENT | 1 | March 27, 2012 02:01 |
help: results depend on writeInterval | ckoch | OpenFOAM | 2 | September 1, 2010 18:42 |
