March 11, 2020, 05:35 |
pimpleFoam RigidBodyMotion restraint issue
Max Spencer
Rep Power: 6 |
I am trying to simulate the rigid body motion of a body in a flow of water and am having issues with what appears to be getting the restraints to work properly. I have built my setup from a combination of the wingMotion 2D and the DTCHullMoving tutorials. I'm starting by running a simple foam case to steady state and then moving to pimpleFoam as done in the tutorials.
Pimple starts and runs okay for the first 5-20ms with Co <1. Then on one time step the solution blows up. From the first results, I can see the body is pivoting about the correct point listed in the transform location of the dynamicMeshDict. But the restraints do not seem to be applied. The linear spring restraints should induce motion in the positive X angular direction. Instead the X angular direction is always negative and building regardless of how I change the spring constraints. (I really need to use the softWall restraints, hence I am using the RigidBodyMotion solver instead of sixDoF, but I am testing with linearSprings for troubleshooting.) My sequence is: 1) simpleFoam 2) copy the simpleFoam/constant/polymesh over to the pimpleFoam/constant directory 3) mapFields from simpleFoam with -sourceTime latestTime -consistent 4) decomposePar 5) run pimpleFoam Is there something in my sequence I am missing to get the restraints to properly act on my solid body? Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object dynamicMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs (rigidBodyMeshMotion); motionSolver rigidBodyMotion; //sixDoFRigidBodyMotion rho rhoInf; rhoInf 1000; rigidBodyMotionCoeffs { accelerationRelaxation 0.4; rho rhoInf; rhoInf 1000; report on; bodies { hull { type rigidBody; parent root; centreOfMass (0.6 0.3 0.06); mass 5; inertia (40 0 0 921 0 921); //(Ixx Ixy Ixz Iyy Iyz Izz) transform (1 0 0 0 1 0 0 0 1) (0.23 0.016 0.05); joint { type composite; joints ( // { // type Pz; // } { type Rx; } { type Ry; } { type Rz; } ); } patches (motorBikeGroup); innerDistance 0.001; outerDistance .5; // mergeWith pivot; } /* pivot { type masslessBody; // parent root; transform (1 0 0 0 1 0 0 0 1) (0.23 0.016 0.05); joint { type composite; joints ( { type Pz; } { type Rx; } { type Ry; } { type Rz; } ); } mergeWith hull; } */ } solver { type Newmark; } } restraints { /* lowerWall_restraint_brush_front { type softWall; body hull; anchor (0.03 0.312 0.017); refAttachmentPt (0.03 0.312 0.007); wallNormal (0 0 1); psi 2.0; C 0.01; } lowerWall_restraint_brush_rear { type softWall; body hull; anchor (1.528 0.312 0.017); refAttachmentPt (1.528 0.312 0.007); wallNormal (0 0 1); psi 20; C 0.01; } lowerWall_restraint_bumper { type softWall; body hull; anchor (0.23 0.016 0.0122); refAttachmentPt (0.23 0.016 0.0022); wallNormal (0 0 1); psi 20; C 0.01; } */ vertical_spring_front { body hull; type linearSpring; anchor (1.52473 0.313032 0.10731892); refAttachmentPt (1.52473 0.313032 0.00731892); stiffness 500000; damping 1; restLength 0.05; } vertical_spring_rear { body hull; type linearSpring; anchor (0.0295147 0.311627 0.10751479); refAttachmentPt (0.0295147 0.311627 0.00751479); stiffness 500000; damping 1; restLength 0.05; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application pimpleFoam; startFrom latestTime; //startTime 0; stopAt endTime; endTime 0.1; deltaT 1e-5; writeControl adjustable; writeInterval 5e-3; purgeWrite 0; writeFormat ascii; writePrecision 10; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; adjustTimeStep yes; maxCo 0.9; //0.9 functions { /* rigidBodyState { type rigidBodyState; libs ("librigidBodyState.so"); angleFormat degrees; } */ #include "ensightWrite" } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { "pcorr.*" { solver GAMG; tolerance 0.01; relTol 0; smoother GaussSeidel; } p { $pcorr; tolerance 1e-7; relTol 0.001; } pFinal { $p; tolerance 1e-7; relTol 0; } "(U|k|omega)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-06; relTol 0.01; } "(U|k|omega)Final" { $U; tolerance 1e-06; relTol 0; } cellDisplacement { solver GAMG; tolerance 1e-5; relTol 0; smoother GaussSeidel; } } PIMPLE { correctPhi yes; nOuterCorrectors 50; nCorrectors 1; nNonOrthogonalCorrectors 3; residualControl { "(U|p|k|omega)" { tolerance 2e-4; relTol 0; } } } relaxationFactors { fields { p 1; //.3 pFinal 1; } equations { "(U|k|omega)" 1; "(U|k|omega)Final" 1.0; } } cache { grad(U); } // ************************************************************************* // |
pimpleFoam runs slower than rhoPimpleFoam | Kosuke Seto | OpenFOAM Running, Solving & CFD | 3 | May 27, 2023 14:12 |
pisoFoam and pimpleFoam are unstable in foam-extend 4.0/4.1 (misunderstanding ?) | Kombinator | OpenFOAM Running, Solving & CFD | 4 | January 14, 2021 04:10 |
Merge time folder for pimpleFoam case run in two separate PCs | Ruonin | OpenFOAM Post-Processing | 1 | April 24, 2019 06:59 |
rhoCentralFoam inviscid airfoil issue (Foam::error::printStack(Foam::Ostream&) at ??) | kmkb21 | OpenFOAM Running, Solving & CFD | 1 | March 1, 2018 01:07 |
Prism Layer - Core Mesh Boundary Issue | InfernoxCJC | STAR-CCM+ | 7 | November 21, 2017 15:46 |
