--> FOAM FATAL ERROR: invalid path specification |
October 2, 2018, 09:22 |
Przemek
Rep Power: 15 |
Hi All,
I am using OF v1612 and previous calculations were stopped by the solver during the write at 100 s: Code:
Time = 100 Courant Number mean: 0.00949898 max: 0.0999998 deltaT = 0.00030688 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 8.36789e-05, Final residual = 4.06971e-17, No Iterations 5 smoothSolver: Solving for Uy, Initial residual = 2.64402e-05, Final residual = 4.01883e-17, No Iterations 5 smoothSolver: Solving for T, Initial residual = 9.13109e-09, Final residual = 7.86405e-09, No Iterations 5 HeliumConstRho updates thermal properties... Updating G, magG and B... min/max(T) = 1.95, 1.95397 GAMG: Solving for p, Initial residual = 4.87185e-07, Final residual = 6.67495e-09, No Iterations 5 GAMG: Solving for p, Initial residual = 6.6887e-09, Final residual = 1.18949e-10, No Iterations 5 time step continuity errors : sum local = 3.43234e-14, global = 1.20386e-21, cumulative = 2.39346e-19 --> FOAM Warning : From function static bool Foam::IOobject::fileNameComponents(const Foam::fileName&, Foam::fileName&, Foam::fileName&, Foam::word&) in file db/IOobject/IOobject.C at line 131 called with directory: "100" --> FOAM FATAL ERROR: invalid path specification From function Foam::IOobject::IOobject(const Foam::fileName&, const Foam::objectRegistry&, Foam::IOobject::readOption, Foam::IOobject::writeOption, bool, bool) in file db/IOobject/IOobject.C at line 279. FOAM exiting and I started from 90 s. Also I change writeInterval to 200. Now at 290 s I got the same as at the 90 s. I am trying to start from 290 s (which is written) but I get this Code:
Time = 290 Courant Number mean: 3.33408e-09 max: 3.34072e-08 deltaT = 1.2e-10 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 2.32946e-10, Final residual = 4.085e-17, No Iterations 5 smoothSolver: Solving for Uy, Initial residual = 3.60056e-09, Final residual = 4.02081e-17, No Iterations 5 smoothSolver: Solving for T, Initial residual = 4.09535e-06, Final residual = 6.28013e-14, No Iterations 5 HeliumConstRho updates thermal properties... Updating G, magG and B... min/max(T) = 1.95, 1.95397 GAMG: Solving for p, Initial residual = 0.997946, Final residual = 6.70672e-08, No Iterations 36 GAMG: Solving for p, Initial residual = 3.14035e-08, Final residual = 1.16862e-08, No Iterations 5 time step continuity errors : sum local = 5.38063e-22, global = -1.58036e-28, cumulative = -1.58036e-28 --> FOAM Warning : From function static bool Foam::IOobject::fileNameComponents(const Foam::fileName&, Foam::fileName&, Foam::fileName&, Foam::word&) in file db/IOobject/IOobject.C at line 131 called with directory: "290" --> FOAM FATAL ERROR: invalid path specification From function Foam::IOobject::IOobject(const Foam::fileName&, const Foam::objectRegistry&, Foam::IOobject::readOption, Foam::IOobject::writeOption, bool, bool) in file db/IOobject/IOobject.C at line 279. FOAM exiting
best regards pblasiak |
October 4, 2018, 05:11 |
Przemek
Rep Power: 15 |
when I changed 290 dir into 0 via
mv 290 0 but why????
December 7, 2018, 05:36 |
#3 | |
Przemek
Rep Power: 15 |
OK I found the reason of the error. I had in the code (inside function that returns Pair<tmp<volScalarField> > object) this piece of code: Code:
{ mCondDotP_ = -mCoeff_*min(T_ - TSat_,T0); mEvapDotP_ = -mCoeff_*max(T_ - TSat_,T0); tmp<volScalarField> tmCondDotP ( new volScalarField ( IOobject ( U_.time().timeName(), U_.db(), IOobject::NO_READ, IOobject::NO_WRITE ), mCondDotP_ ) ); tmp<volScalarField> tmEvapDotP ( new volScalarField ( IOobject ( U_.time().timeName(), U_.db(), IOobject::NO_READ, IOobject::NO_WRITE ), mEvapDotP_ ) ); return Pair<tmp<volScalarField> > ( tmCondDotP, tmEvapDotP ); } I changed this into Code:
{ return Pair<tmp<volScalarField> > ( -mCoeff_*min(T_ - TSat_,T0), -mCoeff_*max(T_ - TSat_,T0) ); } and now it works well.
March 10, 2020, 11:53 |
Przemek
Rep Power: 15 |
Hi
I have once again problem with tmp object. Now the problem line is Code:
tmp<volScalarField> tGMpGrest ( superFluid->GM()/rho/cp ); GM() function is defined as follow Code:
Foam::tmp<Foam::volScalarField> Foam::myClass::GM() const { if (GM_) { return ( viscosityModelPtr_->AGM()*rhon_*rhos_* pow ( max ( B_*magG_, dimensionedScalar("small", dimensionSet(0,1,-1,0,0,0,0), SMALL) ), 4.0 ) ); } and viscosityModelPtr_->AGM() returns volScalarFields my question is: Is it proper way of returning tmp object in GM()? Or Am I doing something wrong? because I get error: Code:
Time = 2.2 Courant Number mean: 0.00017481894698672 max: 0.00069651797368032 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 0.00014181233747096, Final residual = 3.7125624884409e-17, No Iterations 5 smoothSolver: Solving for Uy, Initial residual = 0.0026592937137461, Final residual = 3.9760413783569e-17, No Iterations 5 --> FOAM Warning : From function static bool Foam::IOobject::fileNameComponents(const Foam::fileName&, Foam::fileName&, Foam::fileName&, Foam::word&) in file db/IOobject/IOobject.C at line 131 called with directory: "2.2" --> FOAM FATAL ERROR: invalid path specification From function Foam::IOobject::IOobject(const Foam::fileName&, const Foam::objectRegistry&, Foam::IOobject::readOption, Foam::IOobject::writeOption, bool, bool) in file db/IOobject/IOobject.C at line 279. https://openfoamwiki.net/index.php/O..._you_use_it.3F where we see Code:
tmp<largeClass> myFunc() { tmp<largeClass> tReturnMe(new largeClass); largeClass& returnMe = tReturnMe(); // Somehow fill the data in returnMe return tReturnMe; } Code:
Foam::tmp<Foam::volScalarField> Foam::myClass::GM() const { if (GM_) { tmp<volScalarField> tReturnMe ( viscosityModelPtr_->AGM()*rhon_*rhos_* pow ( max ( B_*magG_, dimensionedScalar("small", dimensionSet(0,1,-1,0,0,0,0), SMALL) ), 4.0 ) ); return tReturnMe; } Can anybody have some advice?
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
Fatal error: invalid wall function specification | kcc49 | OpenFOAM Running, Solving & CFD | 13 | September 26, 2018 04:07 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
