Fatal error patch type [] not constraint type []
Old   March 22, 2020, 18:42
Post Fatal error patch type [] not constraint type []
David Vazquez
davidvzq is on a distinguished road
Good Day everyone,
I am having trouble running a simple sonicFoam simulation. I tried to take the forward step tutorial and add my own mesh created in GMsh, however I get many whenever I try to adjust the case to the Mesh, specifically the one mentioned in the title.
I realize I have to change some names because I used uppercase letters in my GMsh file, but even when I match these I stumble across various problems.
I guess my main questions are the following:
- What is a boundary type and a physicalType?; and how should I set up the constants in "0" and the "boundary" file polymesh directory?
-Am I setting up my mesh properly in Gmsh?
Below is a link to my case setup which includes the mesh file as well.
https://drive.google.com/open?id=1Gp...i5TtFuQeqd5V22
Thank you so much for your help
davidvzq is offline   Reply With Quote
fatal error, gmsh, sonicfoam
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
SimpleFoam - instable simulation Specialist OpenFOAM Running, Solving & CFD 17 August 12, 2014 04:52
Divergent temperature in chtMultiRegion(Simple)Foam akrasemann OpenFOAM Running, Solving & CFD 13 March 24, 2014 02:54
interFoam/kOmegaSST tank filling with printStackError/Mules simpomann OpenFOAM Running, Solving & CFD 3 February 17, 2014 17:06
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 14:16
