a fully developed pipe flow in LES with mapped BC |
#21 | |
Rep Power: 4 ![]() |
Thanks so much for your advice! I'm now using STARCCM+ to carry out my simulation. When I switch my scheme to MUSCL cubic(I wonder if I have the right understanding of the cubic convective scheme), the upwind mixing factor needs to be decided. May I ask the value of the upwind mixing factor in your setting? Thanks a lot! Regards, Junrui |
#22 | |
CFD_Lovers
Rep Power: 12 ![]() |
By cubic, I mean using a higher order scheme. <<Gauss cubic corrected>> is third-order accurate in OpenFOAM. I hope this helps. Sina |
#23 | |
Thanks a lot for your advice! Actually I use this to obtain a fully developed turbulent profile for another region. I used the central difference scheme and the velocity profile seems close to the experiment results, however the turbulent kinetic energy is small and the pressure gradient is also small. Secondly, when the velocity is mapped to the region in interest, it's not converged. Convergence may be a problem especially for higher order scheme. Have you ever come across this kind of situation? Many thanks to your reply! Regards, Junrui |
#24 | |
I did conduct the RANS simulation first and set the results as the initial set for LES, however, the velocity profile still seems not like fully turbulent flow. May I ask what kind of scheme for convective term did you apply? Thanks for your time. Sincerely, Junrui |
#25 |
Rep Power: 9 ![]() |
Hi Junrui,
What RANS turbulence model did you use? My profile also looks laminar ![]() |
#26 |
#27 | |
Guanjiang Chen
Rep Power: 7 ![]() |
The RANS results will looks time-averaged. The turbulence will occur in the converged LES results I think. The schemes I use are Gauss linear, Gauss limited linear, and Gauss LUST grad(U). Regards, Guanjiang |
#28 | |
Thanks a lot for your advice. Do you think this may have something to do with the B.C. because I use the mapped B.C. in my simulation? And would you mind telling me about the y+ in your LES simulation? I wonder if making sure y+ less than 1 is enough for LES simulation. Regards, Junrui |
Display Modes | |
3D pipe flow - Using UDF's to define fully developed turbulent flow on the inlet | Taz-CFD | CFD Freelancers | 1 | February 21, 2016 11:12 |
Couple outlet to inlet to achieve a fully developed flow. | raghu.tejaswi | Fluent UDF and Scheme Programming | 8 | July 18, 2013 09:04 |
Fully Developed Flow in Star-cd | SMM | STAR-CD | 0 | September 5, 2011 22:08 |
Simulating fully developed flow in a pipe | Tim Donohue | CFX | 1 | November 20, 2007 20:24 |
udf for 3D laminar fully developed flow | salman | FLUENT | 0 | November 9, 2006 21:45 |
