OpenFoam VolumeOfFluid Problem with contactAngle on movingWallWall |
Alle
Rep Power: 0 ![]() |
Dear comunity,
currently i am on a project of modeling a slot die coating process. I am using interFoam. My Fluid come out of the die ( direction minus x ) and will be coated on an moving substrat (movingWall) (movement to positiv y ). The force g is (-9,81 0 0) in the following, i posted my BC. Now my problem is, that i have a thin air-film between the coated fluid and my substrat. My substrate is not wetted but it should. Is this caused by a wrong pressure BC on movingWall? Or is there a bether velocityBC than movingWallVelocity? I already tried a refined mesh, but nothing has changed. FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object alpha.water; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { movingWall { type constantAlphaContactAngle; theta0 120; // limit alpha; //gradient ; none value uniform 1; } fixedWalls { type constantAlphaContactAngle; theta0 60; // limit gradient; value uniform 1; } frontAndBack { type empty; } inlet { type fixedValue; value uniform 1; } outlet { type inletOutlet; inletValue uniform 0; value uniform 0; } } // ************************************************** *********************** // FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { outlet { type totalPressure; p0 uniform 0; } movingWall { type fixedFluxPressure; } wall { type fixedFluxPressure; } inlet { type fixedFluxPressure; } frontAndBack { type empty; } } // ************************************************** *********************** // FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { movingWall { type movingWallVelocity; value uniform (0 0.08333 0); } fixedWalls { type fixedValue; value uniform (0 0 0); } frontAndBack { type empty; } inlet { type fixedValue; value uniform (-0.023 0 0); } outlet { type pressureInletOutletVelocity; value uniform (0 0 0); } } |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
[Other] Openfoam for windows 16.02 [CFD support] -problem with paraview | ditmeyer | OpenFOAM Installation | 3 | May 15, 2017 12:04 |
[OpenFOAM.org] Problem in installing OpenFOAM 2.3.0 !!! | omid20110 | OpenFOAM Installation | 6 | August 1, 2016 11:20 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
