[interFoam] porousBafflePressure BC
Old   April 20, 2020, 22:51
Question [interFoam] porousBafflePressure BC
thetitans is on a distinguished road
I am trying to solve a problem which includes flow passes through a porous baffle (geotextile). I used createBaffleDict to create the baffle. So; It could create a cone shaped porous part. The problem is; the porous jump does not work. I tried every possible combination for the D and I coefficient. I also tried the baffle as a wall and it worked. But, nothing is changing when I make it porous. If I use small coefficients nothing happens, water just flows as it does not exist. If I use large coefficients; the model just breaks.
What would be the possible problem?
Thank you for your help.
thetitans is offline   Reply With Quote
boundary condition, darcy-forchheimer, interfoam, porous baffle
Applying Wall Functions and/or No-Slip to a porousBafflePressure BC Neil Adams OpenFOAM Running, Solving & CFD 0 December 14, 2018 06:40
Error using porousBafflePressure BC with twoPhaseEulerFoam mbuergle OpenFOAM Running, Solving & CFD 3 August 14, 2018 09:25
Oscillating a porousBafflePressure (cyclic) boundary mhasif02 OpenFOAM 0 April 10, 2018 06:45
potentialFoam porousBafflePressure turbulence GRAUPS OpenFOAM Programming & Development 3 January 23, 2014 14:11
porousBafflepressure BC laurent257 OpenFOAM 1 August 24, 2012 16:49
