April 20, 2020, 22:51 |
[interFoam] porousBafflePressure BC
Rep Power: 10 |
I am trying to solve a problem which includes flow passes through a porous baffle (geotextile). I used createBaffleDict to create the baffle. So; It could create a cone shaped porous part. The problem is; the porous jump does not work. I tried every possible combination for the D and I coefficient. I also tried the baffle as a wall and it worked. But, nothing is changing when I make it porous. If I use small coefficients nothing happens, water just flows as it does not exist. If I use large coefficients; the model just breaks. What would be the possible problem? Thank you for your help. |
boundary condition, darcy-forchheimer, interfoam, porous baffle |
Applying Wall Functions and/or No-Slip to a porousBafflePressure BC | Neil Adams | OpenFOAM Running, Solving & CFD | 0 | December 14, 2018 06:40 |
Error using porousBafflePressure BC with twoPhaseEulerFoam | mbuergle | OpenFOAM Running, Solving & CFD | 3 | August 14, 2018 09:25 |
Oscillating a porousBafflePressure (cyclic) boundary | mhasif02 | OpenFOAM | 0 | April 10, 2018 06:45 |
potentialFoam porousBafflePressure turbulence | GRAUPS | OpenFOAM Programming & Development | 3 | January 23, 2014 14:11 |
porousBafflepressure BC | laurent257 | OpenFOAM | 1 | August 24, 2012 16:49 |
