Sereff
Rep Power: 8 ![]() |
Hello everyone,
I was trying to evaluate the turbulence modulation of particles in boundary flow. Eveything runs smoothly for pimpleFoam and DPMFoam and I was able to get some interesting result. But then I tried to compare the result between pimpleFoam and DPMFoam without particle injection ( "active", "coupled", "transient" all set to "false;" in kinematicCloudProperties) just to prove the modulation was indeed due to the particle injection instead of different solver, thus making my concludion more robust. But I failed to do so. It seems that even without the particle injection, the turbulence in DPMFoam simulation was dissipated much faster than the turbulence in pimpleFoam. Does anyone have some ideas? Thanks in advance for any suggestion. Kind regards, |
Herpes Free Engineer
Rep Power: 13 ![]() |
could you please refer to the link at the bottom, if possible?
thanks.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
Sereff
after some digging. it seems to be caused by line 9, which increases the robustness of the solver while introducing extra diffusivity, of pEqn.H from DPMFoam:
surfaceScalarField phiHbyA ( "phiHbyA", ( fvc::flux(HbyA) + alphacf*rAUcf*fvc::ddtCorr(Uc, phic) // <------- THIS LINE! ) ); |
Display Modes | |
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 07:08 |
VISCOUS DISSIPATION | ROBERT | Main CFD Forum | 30 | May 29, 2019 04:21 |
Turbulent kinetic energy and energy dissipation at boundary | mshotm2000 | FLOW-3D | 4 | December 12, 2016 09:44 |
Value of Epsilon (turbulent dissipation)? | Yuby | OpenFOAM Pre-Processing | 10 | February 24, 2015 17:37 |
Turbulent dissipation rate in UDF | John Deas | FLUENT | 0 | February 20, 2009 12:27 |
