What is DTRIS2 - Fatal error?
Old   August 4, 2009, 12:01
Default What is DTRIS2 - Fatal error?
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Hello World.
Unfortunately I'm hitting an error message, which I have never seen before.
When running the case I get this strange error:
Reading field p
DTRIS2 - Fatal error!
  Fails for point number I = 2
  M =  1
  M1 = 2
  X,Y(M)  = -0.199999  -1.0157e-05
  X,Y(M1) = -0.199999  -1.0157e-05
#0  Foam::error::printStack(Foam::Ostream&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1  Foam::sigSegv::sigSegvHandler(int) in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2  ?? in "/lib/libc.so.6"
#3  Foam::timeVaryingMappedFixedValueFvPatchField<double>::interpolate(Foam::Field<double> const&) const in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#4  Foam::timeVaryingMappedFixedValueFvPatchField<double>::checkTable() in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#5  Foam::timeVaryingMappedFixedValueFvPatchField<double>::updateCoeffs() in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#6  Foam::timeVaryingMappedFixedValueFvPatchField<double>::timeVaryingMappedFixedValueFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#7  Foam::fvPatchField<double>::adddictionaryConstructorToTable<Foam::timeVaryingMappedFixedValueFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#8  Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/icoFoam"
#9  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricBoundaryField(Foam::fvBoundaryMesh const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/icoFoam"
#10  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readField(Foam::Istream&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/icoFoam"
#11  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/icoFoam"
#12  main in "/home/sega/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/icoFoam"
#13  __libc_start_main in "/lib/libc.so.6"
#14  _start at /build/buildd/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
Segmentation fault
I don't know what to do with this message.
Be aware that this case it not "ordinary".
I'm toying around with the timeVaryingMappedFixedValue boundary condition.
Maybe there is something wrong, but I don't see it ...
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   August 4, 2009, 17:13
Mattijs Janssens
mattijs is on a distinguished road
timeVaryingMapped does a triangulation of the supplied points. You'll get this error if you don't have enough points for a triangulation or they are not in a plane. It works out the plane from the first three points. Switch on its debug flag to see which points it uses.
mattijs is offline   Reply With Quote
Old   August 4, 2009, 17:23
sega's Avatar
Sebastian Gatzka
Sounds promising. Can you tell me how I switch on a debug flag?
Old   August 5, 2009, 14:08
Mattijs Janssens
Section 3.2.5 in the user guide.
Old   August 6, 2009, 11:25
sega's Avatar
Sebastian Gatzka
Thanks.
So, now I put the entry
DebugSwitches
    timeVaryingMappedFixedValue 1;
at the bottom of my controlDict but this changed nothing in the output.
How does this Debug Switch work?
Old   August 6, 2009, 12:55
sega's Avatar
Sebastian Gatzka
Please, consider this problem solved.
I made a severe error with the discretisation which had nothing to do with the boundary condition itself!
Old   August 26, 2009, 09:53
sega's Avatar
Sebastian Gatzka
Sorry mattijs. I have to get back to this problem.
On slightly different geometry I get similar errors with the triangulation.
This time its a "real" problem as I didn't do stupid mistakes with the geometry itself.
First of all I need to know how the debugging flags work (switching them on was easy - see post from August 6th), but I don't know how to extract information out of it.
Just to make this right: The first three points are not forming a plane and that is causing the trouble?!
Old   August 27, 2009, 04:50
Mattijs Janssens
I assume that is the problem. Run e.g. the pitzDailyExptInlet with the debug switch on and check especially what the first three points are (used to define the coordinate system). I assume your points are on a line or too close together and the (2D) triangulation routine (Geompack) does not get a correct set of points.
Old   August 27, 2009, 04:58
sega's Avatar
Sebastian Gatzka
Ok, I did it. But I can't find any output connected to the Debug switch.
Is there a file created, or anything similar to look at?!
Old   August 27, 2009, 08:30
sega's Avatar
Sebastian Gatzka
AHA! You don't have to add the DebugSwitch to the cases controlDict!!!
You have to switch it on at the "global" controlDict!?!
(~/OpenFOAM/OpenFOAM-1.5/etc/controlDict)
Well this was not clear to me from the description in the Users Guide!
Old   August 27, 2009, 08:35
sega's Avatar
Sebastian Gatzka
So here we go with the output with activated debug switch!
|  \\    /   O peration     | Version:  1.5                                   |
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
Exec   : icoFoam
Date   : Aug 27 2009
Time   : 14:29:44
Host   : deepblue
PID    : 13295
Case   : /home/sega/OpenFOAM/sega-1.5/run/arcSmall0
nProcs : 1
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
timeVaryingMappedFixedValue : construct from dictionary
timeVaryingMappedFixedValueFvPatchField : Read 560 sample points from "/home/sega/OpenFOAM/sega-1.5/run/arcSmall0/constant/boundaryData/f0/points"
timeVaryingMappedFixedValueFvPatchField : Used points (1.12104 0.996177 0.8125) (0.808544 1.26307 3.9375) (1.19574 0.90515 2.5625) to define coordinate system with normal (0.693676 0.720244 0.00785374)
readSamplePoints : Dumping triangulated surface to triangulation.stl
readSamplePoints : Dumping face centres to "/home/sega/OpenFOAM/sega-1.5/run/arcSmall0/localFaceCentres.obj"
timeVaryingMappedFixedValueFvPatchField : In directory "/home/sega/OpenFOAM/sega-1.5/run/arcSmall0/constant/boundaryData/f0" found times
21
0
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
1.1
1.2
1.3
1.4
1.5
1.6
1.7
1.8
1.9
2
findTime : Found time 0 inbetween index:0 time:0 and index:1 time:0.1
checkTable : Reading startValues from "boundaryData/f0/0"
checkTable : Reading endValues from "boundaryData/f0/0.1"
updateCoeffs : Sampled, interpolated values between start time:0 and end time:0.1 with weight:0
updateCoeffs : set fixedValue to min:0 max:0
timeVaryingMappedFixedValueFvPatchField : Read 560 sample points from "/home/sega/OpenFOAM/sega-1.5/run/arcSmall0/constant/boundaryData/f1/points"
timeVaryingMappedFixedValueFvPatchField : Used points (1.13735 0.636946 1.9375) (1.16851 0.654397 1.9375) (1.19967 0.671848 1.9375) to define coordinate system with normal (0 0 -1)
  M =  1
  M1 = 2
  X,Y(M)  = -0.28571  -3.97859e-06
  X,Y(M1) = -0.28571  -3.97859e-06
timeVaryingMappedFixedValueFvPatchField : In directory "/home/sega/OpenFOAM/sega-1.5/run/arcSmall0/constant/boundaryData/f1" found times
21
0
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
1.1
1.2
1.3
1.4
1.5
1.6
1.7
1.8
1.9
2
checkTable : Reading startValues from "boundaryData/f1/0"
Segmentation fault
Let me tell you what I read from it and maybe you can tell me if I am right?!
So the triangulation for the first patch is ok, but in case of the second face the points are one a line!
Meaning they have equal x3-Coordinates:
So to work around this I have to have points at different x3-locations?
Right?
Old   August 27, 2009, 09:35
sega's Avatar
Sebastian Gatzka
Please forgive my impatience. Its obvious that there is a problem with the three points from above being in a line.
What you have to know is that I am gathering the points from a small code I wrote myself. So to avoid such problems with the triangulation I need to know what the condition for a successful triangulation is!
Than I can check the condition while collecting the points and maybe can do some switching to get the right points on top of the list.
Do you understand what I mean?
Old   August 27, 2009, 09:59
sega's Avatar
Sebastian Gatzka
I think I have found the condition and moved with the related questions to a different thread:
http://www.cfd-online.com/Forums/ope...ixedvalue.html
Maybe someone can tell my if I'm on the right track chasing this condition?
Old   February 23, 2012, 03:48
camoesas is on a distinguished road
HI,
I am trying to use the timeVaryingMappedFixedValue Function. I´ve already written my files to the boundaryData folder. But now I don´t know how to proceed. How can I triangulate these Values to my BC file in the time Folder.
timeVaryingMapped is unknown to my OF installation. I have checked various other (older as well as newer) installations but I never found a utility like this. Is this the correct name? How can I proceed from my state?
Thanks!
OF - 2.0.0
camoesas is offline   Reply With Quote
Old   February 24, 2012, 03:00
Alberto Passalacqua
The "mapped" conditions changed in OpenFOAM 2.1.x, however the same operations can be performed:
http://www.openfoam.org/version2.1.0...conditions.php
Alberto Passalacqua
Old   February 24, 2012, 05:20
thanks for the link, but its no use for me because I am using OF 2.0
OF - 2.0.0
Old   February 24, 2012, 13:04
Alberto Passalacqua
Them it is timeVaryingMappedFixedValue (See: ~/OpenFOAM-2.0.x/src/finiteVolume/fields/fvPatchFields/derived/timeVaryingMappedFixedValue/ ).
Best,
Alberto Passalacqua
Old   February 28, 2012, 03:57
HI Alberto,
I guess we are at cross-purposes. I am not searching the name for the BC, what I am missing are the values within this BC. During runtime I get this error:
size 4 is not equal to the given value of 269
So I need the utility to map my data (given in: constant/boundaryData/Patch/points and constant/boundaryData/Patch/timeDirectory/variable) to the variable in the Time directory given below. The Utility must interpolate from my 4 given values the values for all 269 nodes on this patch.
I searched for an utility something like 'timeVaryingMapped' as it is written earlier in this thread. But this is completely unknown to OF (1.5; 1.7; 2.0; 2.1)
These are the files I am using so far:
my BC file is:
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 301.5;
boundaryField
    HOT
        type            timeVaryingMappedFixedValue;
        setAverage      0;
        value           nonuniform List<scalar>
       4
          316
          325
          341
          341);
    IN
        type            fixedValue;
        value           uniform 301.5;
    OUT
        type            zeroGradient;
    TOP
        type            symmetryPlane;
    EMPTY
        type            empty;
    WALL
        type            zeroGradient;
    SYM
        type            symmetryPlane;
constant/boundaryData/points:
 // min y
  (0.2 0 0.0125)
  (0.25 0 0.0125)
  (0.3 0 0.0125)
  (0.8 0 0.0125)
 // max y
  (0.2 0.5 0.0125)
  (0.25 0.5 0.0125)
  (0.3 0.5 0.0125)
  (0.8 0.5 0.0125)
constant/boundaryData/Patch/0/T
// Average
0
// Data on points
8
//miny
316
325
341
341
// maxy
316
325
341
341
Thanks Camoesas
OF - 2.0.0
Old   February 28, 2012, 04:21
Alberto Passalacqua
OK. I misunderstood your question before. Sorry about that.
If the geometry is simple, with some coding you could print out the face centres of the patch corresponding to your BC, and use those to create your input.
As an alternative, if you can provide a functional expression to your BC, you could use GroovyBC (it's on the OpenFOAM wiki, as part of swak4Foam http://openfoamwiki.net/index.php/Contrib/swak4Foam ).
Alberto Passalacqua
Old   February 28, 2012, 06:37
Hey alberto,
I thought there is maybe an automatic way to map my values to the BC.
(quite naive to think so, this is OF )
So I have to hard code it in my BC File? I have read about a utility to write out the cell centers. I hope I find it again
What for do I specify the 'points' file and the values in constant/boundaryData/Patch/time/variable if I cant map it to my BC File? Is this just for later times?
Thanks
OF - 2.0.0
dtris2
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
